Get rid of those bent axles!
   / Get rid of those bent axles! #1
dusty3030
West TN
Kubota MX5400 Cab, Kioti RX7320 PS/ Cab, Kubota M7040 HDC, John Deere 2355, Kubota U35-4, John Deere 317G
   / Get rid of those bent axles! #2
Well no camber is going to be better than that really bent one. But I dont see the person who's overloading a trailer that much even knowing there axle is supposed to be bent..but the other way.
   / Get rid of those bent axles! #3
In his spare time maybe he could straighten some of those semi flatbeds I see going down the road. Honestly, how do they get away with such an obviously unsafe trailer? Empty they have a big upward bow in them. The metal is so fatigued that when loaded, that bend straightens right out. It ain't right I tell you!
   / Get rid of those bent axles! #4
I would think someone with a machine that large and the capabilities to use it would understand how this works.
   / Get rid of those bent axles! #6
Redneck Trailer Supplies builds axles to order and has distribution centers across the US. I've had axles built there for customers a couple times and the process is smooth and efficient.
We used to haul axles made at Dexter Axle in Elkhart, IN to a few Redneck factories. They must have decided to build them themselves.
   / Get rid of those bent axles! #7
   / Get rid of those bent axles! #8
For all I know Redneck farms the builds out to Dexter. That wouldn't be all bad. They are, after all a distribution and retail business, not a manufacturer.
   / Get rid of those bent axles! #9
Perhaps those trailers are purposely designed that way. If the empty trailer always returns to the bowed position the material is not fatigued.
   / Get rid of those bent axles! #10
Long time ago I heard they are designed so when load is maxed out the axles will be straight and even with semi flatbeds the trailers will be flat when loaded down.
RIPPER ATTACHMENT FOR MINI EXCAVATOR (A58214)
RIPPER ATTACHMENT...
New/Unused Quick Attach Auger with Three Bits (A57453)
New/Unused Quick...
202477 (A54757)
202477 (A54757)
2009 Ford F-250 4x4 Ext. Cab Pickup Truck (A56858)
2009 Ford F-250...
WOOD GRABBER FOR MINI EXCAVATOR (A58214)
WOOD GRABBER FOR...
New/Unused Electric Golf Cart (A57453)
New/Unused...
