4WD light on DK4510
/ 4WD light on DK4510 #1
Nancy Kowalski
Kioti DK4510HS
Hi there. I see a warning light for when the 4WD is engaged. I noticed that mine does not light up when the 4WD is activated. I know for a fact that the 4WD system is working having used it to get my self out of some stuck situations.
Should I have dealer do the warranty work on this?
/ 4WD light on DK4510 #2
Hi Nancy Welcome to the forum.
Unfortunately indicator lights on Kioti are something special. In some markets and models they work in others they don't, it just depends on what regulations they have to follow. I have a bunch of indicators that I can see on my dash but only a few work. Someone else with the same machine will have to chime in to see if yours is set up to have the pto light working.
/ 4WD light on DK4510 #3
The 4wd indicator on the instrument panel isn't used on the DK10 models, I suspect because the instrument panel is also used on the larger models that have electric engagement for the 4wd.
/ 4WD light on DK4510 #4
Exactly right. Many of the CK and newer DK series that have manual engagement will have the position and even the light bulb but will not actuate when in 4WD by design. My older DK series tractor has a working 4wd light. In fact two of them. One on the dash and the other is the electrical switch itself lights up with in 4WD. But again this is an electrical over hydraulic actuation.
/ 4WD light on DK4510 #5
Is there a simple plug and play option that can get this working as it should?
/ 4WD light on DK4510 #6
No. Some of the lights are only active on the European models. The lights are in the dash but only light during the initial "test" when you turn on the ignition. Traced out the wiring diagrams and could see the terminals on the MCU on the US drawings have no connections but on EU drawing it shows circuits for 4WD and QT (for example) that are not available here. I looked to confirm whether the wiring harness had anything near the switch location to tie into for adding a micro-switch to the lever but the wiring (for the switches) is not there, also indicated in drawing. The switch would be right above the parking brake. Nothing for QT/4WD but that is where the OBD2 port is. The QT (quick turn) feature uses steering position sensors to bias the hydro to the rear wheels to assist steering.
/ 4WD light on DK4510 #7
On my DK35SE the only issue is in direct sun it's hard to read and otherwise my knee hits it when I'm playing log rodeo in the woods. I see the DK4510 has moved the switch under the steering column so I thought all was well now?
/ 4WD light on DK4510 #8
Switch? My "lever" is under my left knee and I think "up" is 4wd and "down" is 2wd. I can't remember and it is hard to lean forward enough to see the tiny pictures that are almost identical. :LOL:
/ 4WD light on DK4510 #9
Just like the diff lock, stomp for traction (4wd) :)
/ 4WD light on DK4510 #10
my 4x4 switch lights up, and a light on the dash lights up. but its a 2010 DK45. youll have to ask your dealer
/ 4WD light on DK4510 #11
You said that your DK45 has a switch. My DK4510 has a lever instead of a switch; there is nothing to even tell the MCU to turn the light on, much less to tell the MCU to turn on the 4wd solenoid. The DK10 Series apparently dropped that feature for the US market. The only thing that we get here in the US is a light that momentarily turns on when you turn the key. No switch, no wires, no solenoid, just a lever.
:censored:
/ 4WD light on DK4510 #12
:censored:
Pretty sure we don't have Quick Turn either, at least not my CK10. Would really help in my sandy soil. The fronts get pushed here sometimes in a a turn.
/ 4WD light on DK4510 #13
Nope, but we got the light! 🥳
/ 4WD light on DK4510 #14
Very in detail. Thank you so much !
/ 4WD light on DK4510 #15
I emailed kioti about the 4wd light and was told it was only used on European models. Mine is there but only on startup. DK5510, 2018.
2013 International WorkStar 7500 29Yd. Side Loader Garbage Truck (A64194)
2013 International...
2016 JOHN DEERE 7210R TRACTOR (A64280)
2016 JOHN DEERE...
Quick Attach Backing Plate (A65579)
Quick Attach...
Fork Extensions (A65640)
Fork Extensions...
2005 MACK CV713 MIXER TRUCK (A65643)
2005 MACK CV713...
2020 CATERPILLAR D5K2 LGP CRAWLER DOZER (A65053)
2020 CATERPILLAR...
