Rear blade for snow on gravel, pipe or rubber mat?
   / Rear blade for snow on gravel, pipe or rubber mat? #11
I have some sort of yellow synthetic edge on mine but it’s asphalt and I don’t think it would work that well on gravel.
   / Rear blade for snow on gravel, pipe or rubber mat? #12
~125yrd driveway here, I just flip the blade around for the first snow so it packs a base-layer. With a better base layer I can then flip the blade around for the rest of the season.
   / Rear blade for snow on gravel, pipe or rubber mat? #13
I've seen some small clamp on skis or skids that seem to work quite well.
They are called "EDGE TAMERS"
In fact I made similar devices for my snow blower, well actually added oversize bottoms to existing skids.
   / Rear blade for snow on gravel, pipe or rubber mat? #14
Tried both and feel the pipe was much better. That's what I stayed with. I use a galvanized pipe, about 1.25" OD.
   / Rear blade for snow on gravel, pipe or rubber mat? #15
The best practice for plowing a gravel driveway is to never let the plow touch the gravel...ever. get a nice snow pack on it then plow to the surface. If you ever need to let the plow touch the gravel plow it to a place that's not in your lawn and you can leave it until spring. Doing these few things really cut back on my spring time gravel raking. I now have a snow blower but just hope that I'm not now raking the stone from 40ft away.
   / Rear blade for snow on gravel, pipe or rubber mat? #16
How did you attach the pipe? any pictures?
   / Rear blade for snow on gravel, pipe or rubber mat? #17
As has been mentioned I run my blade backwards while pulling when the driveway is not frozen,
once it's frozen I turn it around and pull forward.
Pulling a blade forward on frozen ground
Pulling a blade backwards on non frozen ground
   / Rear blade for snow on gravel, pipe or rubber mat? #18
An interesting theory, but not workable on most driveways around here. Especially the section of mine with 14% slope that faces north. After a couple of passes with a vehicle it becomes a sheet of ice that provides a very quick trip to the bottom of the hill, and you can't scrape it off until it melts in its own sweet time.
   / Rear blade for snow on gravel, pipe or rubber mat? #19
Whats the avg snow in Boone?
   / Rear blade for snow on gravel, pipe or rubber mat? #20
Gravel naturally gets thrown out of the driveway by traffic, as well as by plowing snow. If you can't stand that your only choice is to pave it.
That’s not the only choice. I turn my blade around backwards and it pushes snow without moving gravel.
1336 (A57192)
1336 (A57192)
2014 Ford Escape SUV (A55853)
2014 Ford Escape...
John Deere 1025R (A53317)
John Deere 1025R...
2020 Chevrolet Silverado 1500 Pickup Truck (A55852)
2020 Chevrolet...
Stainless Steel 1" Spool (A52377)
Stainless Steel 1"...
