/ Share Pics of People Hauling or Towing Something Wrong #15,221
(from the net)
/ Share Pics of People Hauling or Towing Something Wrong #15,222
He lost that race!
/ Share Pics of People Hauling or Towing Something Wrong #15,223
He won't be hauling for while.
/ Share Pics of People Hauling or Towing Something Wrong #15,224
That was one expensive race for him. Those windmill blades aren’t cheap.
You have to wonder about his escort driver though.
/ Share Pics of People Hauling or Towing Something Wrong #15,225
The issue appears to be due to whoever planned that route, mostly. The driver too in part. The intersection wasn't wide enough for that length of load to make the turn. The timing of the train was just the bad luck piling on.
/ Share Pics of People Hauling or Towing Something Wrong #15,226
Trains run on schedules, which could be confirmed and taken into account. Any way that I look at it though, the driver was depending on his support team and they dropped the ball.
/ Share Pics of People Hauling or Towing Something Wrong #15,227
A long blade takes longer than usual to clear an intersection. Very likely here was no indication of coming train when the driver crossed the track. No sight of train as far as one could see.
/ Share Pics of People Hauling or Towing Something Wrong #15,229
The truck wasn't just slow going through the intersection, it was too long to actually make the turn. That's why it was initially stopped and why it ended up taking out the far side RR crossing arm/light when he finally decided to just GTF out of the way and. It should never have been on that route.
/ Share Pics of People Hauling or Towing Something Wrong #15,231
Those blades aren't used in singles. Where was it coming from? Where was it going? How did the others get from A to B?
/ Share Pics of People Hauling or Towing Something Wrong #15,232
That’s how they transport them, and I doubt that the driver chose the route to take. I also still can’t believe they couldn’t check the train schedule and plan for it. At least it wasn’t ammonia or some other toxic chemical.
/ Share Pics of People Hauling or Towing Something Wrong #15,233
Text says the truck had escorts. So someone other than the driver was leading. Also says most semis use a different route straight over the railroad tracks avoiding the sharp turn.
/ Share Pics of People Hauling or Towing Something Wrong #15,234
Out here it's a common sight to see one blade on a flatbed heading from and to parts unknown. In fact, I've never seen more than one. They are shockingly long.
/ Share Pics of People Hauling or Towing Something Wrong #15,235
Truck driver is lucky they didn’t get carried down the tracks for 3/4 of a mile by the train engine bouncing off every building as you go.
/ Share Pics of People Hauling or Towing Something Wrong #15,237
I hope no emissions were created in the making and transportation of that blade. Otherwise how could the electric vehicle be “zero emissions”?
/ Share Pics of People Hauling or Towing Something Wrong #15,238
As chemicals go, ammonia is one of the easiest to clean up from afterwards, just wash everything down with water.
And it stinks enough to let you know that it's there long before it gets to a concentration where it will do anything more than clean out your sinuses.
Aaron Z
/ Share Pics of People Hauling or Towing Something Wrong #15,239
that will buff right out (y)
/ Share Pics of People Hauling or Towing Something Wrong #15,240
Had they used a trailer like this and the train would've probably just sneaked right under it. 🤣
2012 INTERNATIONAL PROSTAR+ (A58214)
2012 INTERNATIONAL...
2012 International Prostar (A61306)
2012 International...
2021 Deere 331G (A53317)
2021 Deere 331G...
UNUSED FUTURE HYD HEDGE TRIMMER (A52706)
UNUSED FUTURE HYD...
2022 FORD E350 BOX TRUCK (A58018)
2022 FORD E350 BOX...
2017 Chevrolet Express 2500 Cargo Van (A59230)
2017 Chevrolet...
