dead center
/ dead center #1
ed1978
Member
kubota b-7100hst
off topic subject here. just giving you folks something to really think about. the exact center of a rotating shaft or object does not rotate. thus the phrase dead center. think about this.
/ dead center #2
It rotates, but it doesn't travel due to the rotation like every other point on the rotating object.
/ dead center #3
Based on what I read that is still up for debate. I can see the argument for both answers.
/ dead center #5
I guess this is true in the theoretical geometry sense that a "line" through the exact center of a "cylinder" might not rotate when the cylinder rotates. But it's important to also remember that this line is a theoretical 1-dimensional concept that has no width, only length. I don't think this really translates with any practical value in the notion that the "center" of a "shaft" doesn't rotate.
"Dead center", "dead slow", "dead reckoning", "dead-on" -- I think they're all descriptive but don't necessarily indicate lack of movement.
/ dead center #6
Without looking up the mechanical theory on the subject...It seems to me that any point on a diameter line would be rotating at the same RPM as any other point...
...i.e., the RPMs do not get progressively less towards the center it (RPM) remains constant...if the center is part of the same mass how can it not be rotating ?
question for the OP...what size is the shaft (moot) but what size is the "center" one molecule ?
/ dead center #7
I true dead center is fit into the headstock of a lathe. A live center is fit into the tailstock. If you want to turn a taper then you offset the tailstock. Of course this was before CNC machines.
Our next class will cover centerless grinding.
What did I win? LOL
/ dead center #8
Even molecules rotate. I don't know if photons do (I suspect not), but atoms and electrons do too.
If the cylinder is a fluid, it's quite possible that the very center literally doesn't rotate (ref: eye of the hurricane - the closer to the center of fluid rotation you get the less rotation there is... off topic - the rate of flow of a fluid approaches zero at the wall of the conduit, which is why you get crap deposited in pipes and on fan blades), but I'm pretty sure we're talking about solids here.
/ dead center #9
I need to figure out a way to mount my mower spindles at this dead center point so I can eliminate the need for bushings and grease fittings.
/ dead center #10
..."Dead center", "dead slow", "dead reckoning", "dead-on" -- I think they're all descriptive but don't necessarily indicate lack of movement.
Don't forget the Grateful..
/ dead center #11
According to a special ed course, just look for the part that is not rotating.... but don't do that while the spindles are "spinning"... :eek:
/ dead center #12
Just spin the rest of everything around the fixed spindle and you'll be fine
a bit dizzy perhaps
Paladin 544K 416 IC 105in. Dual Cylinder Hydraulic Loader Attachment (A61567)
Paladin 544K 416...
BUSHHOG 2615 LEGEND BATWING MOWER (A63276)
BUSHHOG 2615...
1991 PROLITE GOOSENECK HORSE TRAILER (A62130)
1991 PROLITE...
02GER CHICKET HOUSER 240F (A62131)
02GER CHICKET...
Arrowquip Heeler Portable Corral (A64047)
Arrowquip Heeler...
2023 John Deere 6120M Tractor (A63109)
2023 John Deere...
