JWR
Elite Member
- Joined
- Apr 19, 2011
- Messages
- 4,139
- Location
- So MD / WV
- Tractor
- MF 2660 LP, 3 Kubota B2150, Kubota BX2200, MH Pacer, Gravely 5660, etc.
I don't really know the 3pt rating on the tractor [just looked it up and find it is 3391lbs] but it had no problem at all lifting the ORSI, you just did not dare to leave it hanging there without the support underneath. The ORSI model I have claims in literature to be OK with a 50 hp tractor. Mine is 81HP and been dyno tested putting out 90hp. Of course it is weight and rear tire track that matter, not HP. I suppose with the loader my MF2660 low profile weighs about 9,000lb with loaded tires, etc. The dry weight [of the ORSI] is over 2200 lbs , not 2700 lbs, but the oil tank is huge and then you have the support structure, stab arms, etc.I bet that thing is a PITA to hook up. You need to be a contortionist to get the PTO attached.
I have had this mower tip me over sideways (lift the rear tire off the ground) attempting to use it fully extended on a side slope (!!) After the GULP I realized it was only going to tip far enough for the mower to rest on the ground which then became an outrigger instead of load on a lever ! I then pulled it in closer and got off the slope. My rear tires are 8ft apart outer edge to outer edge. Would go wider but that creates trailer issues. If I were going to use ORSI a whole lot more I would definitely widen the rear wheels more (I have about another 10 or 12 inches I could go.)
The PTO is the least of the problem hooking up. That goes on rather easily. But the heavy stabilizer arms and several pins to get in place & line up all add up in mounting time. Because the thing is PTO driven it is VERY robust and will pretty much cut anything that gets in the way. Has two of it's own hydraulic pumps, one for positioning and one for cutting. I have been pleasantly surprised to find no debris slinging at me in the tractor seat with an open station tractor and all the hell breaking loose out there at the end of the arm. It is a great tool for overhanging limbs, ditches and especially cutting brush grown up in sink holes around the farm. An old WV farm is automatically hilly and in 100 acres I probably have at least 9 or 10 sink holes that would bury the rear wheels on a large tractor if you did not know the land inch by inch.
