Cub cadet gt 2544 with kohler command ch 670 after 15 to 30 minutes sputters like it’s getting no fuel then dies.
   / Cub cadet gt 2544 with kohler command ch 670 after 15 to 30 minutes sputters like it’s getting no fuel then dies. #51
Be sure you have clear fuel line from the tank to the carb - free flow, no blockage. Have you replaced the fuel filter lately.
   / Cub cadet gt 2544 with kohler command ch 670 after 15 to 30 minutes sputters like it’s getting no fuel then dies. #52
Also that fuel tank vent not obstructed.
My guess is something floating around tank and getting into filter...
   / Cub cadet gt 2544 with kohler command ch 670 after 15 to 30 minutes sputters like it’s getting no fuel then dies. #53
Will it start right back up or do you have to let it sit for awhile?
could be fuel or spark or compression Pull plug when it stops and check for spark when engine is still hot. If possible check compression when hot.
Fuel loss: a short spray of flammable carb cleaner in the carb does it fire? If yes then you are not getting fuel and need to start fuel components.
   / Cub cadet gt 2544 with kohler command ch 670 after 15 to 30 minutes sputters like it’s getting no fuel then dies. #54
You have three other threads on this including one where you said you'd gotten it fixed and it was working fine......
I know I just want more opinions.
Has spark when hot. I could restart it but it would die with in seconds
New fuel cap and filter and fuel lines.
Yes fresh fuel filter and good fuel line
Maybe residue build up with in carburetor put carburetor cleaner in gas tank,may take couple times
It would surge would that cause it to surge
   / Cub cadet gt 2544 with kohler command ch 670 after 15 to 30 minutes sputters like it’s getting no fuel then dies. #60
If it has spark and will restart points towards a fuel delivery issue but I would double check compression since that is also a little to no cost item and eliminates another potential problem. Next step is checking fuel flow into the carb which is more difficult since you can not see into the carb. Not common but float needle can stick closed preventing fuel from getting into the carb and this is difficult to ID again because you can not see into the float bowl.
Does you carb have a drain plug in the float bowl? Is it accessible when the engine is hot and not close to exhaust or any ignition point? If you can safely remove this plug with a hot engine it would tell you if the float bowl is full of gas or not.
202480 (A54757)
202480 (A54757)
Grey Metal Roof Panels (A55758)
Grey Metal Roof...
2018 JCB Truss Jib Telescopic Hydraulic Boom (A55787)
2018 JCB Truss Jib...
EZGO (A50324)
EZGO (A50324)
(3) ROLLS OF 4' GALVANIZED FIELD FENCE (A54757)
(3) ROLLS OF 4'...
2017 Ford F-150 Pickup Truck (A55788)
2017 Ford F-150...
