Live Animal Traps
/ Live Animal Traps #22
For a real life version of that vid, search for Badass Texas Rabbit
As in, don't mess with a mamma ANYTHING :eek: ... Steve
/ Live Animal Traps #25
+1 Agree, Raccoons are mini bears with an awesome bite. Last year they chewed a plastic wheel off the grill! 🦝
i've had coons go through plastic buckets of grain with ease, but still surprised at the gnawed wire escape. OP: do badgers roam your area? i surely would train a cam on the trap & post (you have no choice now :)
also: using what kind of bait? i may have missed that
/ Live Animal Traps #26
Mink,there's mink all over Mn,they are tough and can easily fit through that hole. It could have made the hole to escape or was passing by, spotted a trapped chipmunk, helped him escape then invited him to dinner.
/ Live Animal Traps #27
Where was the bait placed in the trap @Richard001? And what kind of bait. From the pictures it looks like the bait was probably placed close to that hardwire cloth. I have had some pretty big raccoons bend and twist some strong traps.
I’ve also had some reach in from the outside to grab bait and I would find the trap empty, tripped and all bait gone.
In this case I’m betting the ‘coon tore through the wire from outside and stole the bait.
Please take the suggestion to put a game camera on it. It will be some great video.
Don’t reinforce the wire until you get the video and clear Up this mystery. But when you do, you should leave the Hardware cloth attached to the wood and place the stronger wire over it. That way you will probably keep the little bandit from robbing your bait from the outside.
/ Live Animal Traps #28
I have trapped a couple dozen raccoons. It is better to have a commercial live trap out of heavy duty wire that they can see through. I put cat kibble in a plastic container (like from cottage cheese), put a wire through one edge on the top and hang it in the very back of the cage. To reach it they have to step on the platform to trip it. You need to test the platform that it will trip easily (use stick). I've also trapped many feral cats to get then fixed.
/ Live Animal Traps
Well that is an interesting theory. However the trap door it tripped by a plate that is inside the the trap. No I suppose that with enough vigorous movement of the trap, the trigger could go and let the door down.
An interesting side note to this story is that I have a aluminum piece of metal attached to a poison bait to keep the bait box from disappearing, you know, being dragged off.
Not knowing what has been chewing on the aluminum piece, I placed my trail camera to view the aluminum piece. Well today I see that it is a squirrel that is chewing on it. I would have never guessed that. I will get the photo of the aluminum piece on here soon.
/ Live Animal Traps #30
This is getting more interesting. I could see a squirrel biting through that hardware cloth.
i don’t understand this: An interesting side note to this story is that I have a aluminum piece of metal attached to a poison bait to keep the bait box from disappearing, you know, being dragged off.
If they target has to go inside to get the bait and trip the trigger to shut the door why do you need a poison bait to keep the bait box from being dragged off?
/ Live Animal Traps
OK sorry for the confusion. The live trap was at my friends house and that is were the hole in the screen occured.
Now this is some thread drift, but the poison bait thing is in my back yard. The poison bait is one of those that you can buy at your local big box store. It's a D-Con bait box. I attach the bait box to something larger and heavier because in the past, the box gets dragged away, never to be seen again. In this case, I attached an Aluminum piece to the box with a wire. Here is a photo of the Aluminum piece showing marks:
Here is a close up of it:
Until yesterday, I had no idea what was doing this.
This is a screen shot of a video from my trail camera.
This is under my deck on the back of my house. I have no idea what a squirrel would find tasty on a piece of AL.
/ Live Animal Traps #32
On raccoons, a neighbor had a wet bar on his screened porch.
Darn coons pried open a hole, opened his bar and with their clever little hands opened every liquor bottle in the bar.
They preferred al the sweet liquors and left the scotches and ryes to self drain.
What a horrible sticky mess and waste of good spirits.
/ Live Animal Traps #33
I find that not too surprising actually. Here in the Florida Panhandle, squirrels eat the aluminum tie wires off chain link fence like it's going out of style. It seems like it's a delicacy for them. Even better than going to the Colonels for dinner.
/ Live Animal Traps #34
Indiana also has the chainlink fence problem. Squirrels' teeth grow rapidly to enable them to eat hard Hickory nuts. However, if their primary food source isn't that hard (bird seed for example) they must chew the tie wires to reduce tooth growth.
/ Live Animal Traps #36
I had a groundhog do that to one of my traps. Groundhog was much larger then the whole he got out of.
/ Live Animal Traps #37
so.....after all this talk, are squirrels the culprit as confirmed by game cam? several critters are capable from what it seems... but i'd like to know, best regards
/ Live Animal Traps #39
I have had a bit of experience with live traps.. A couple homemade models from lumber and ply wood..
Here in the far north the thing that could chew a hole the size in the picture shown and escape from that hole would be a long tail weasel.. I routinely have to live trap one spring, fall, both from the vestibule of our chicken house..
A few things to start with...
Several tricks I have found that help... Fasten 1/4" hardware cloth over the front of the trap and across the top and down the sides about a quarter the length of the trap.. This to keep small paws from tripping the trap pan or stealing bait from the outside..
Always stake down, or tie up the trap so a caught animal can not reach out and turn the trap on its side or upside down.. Keeping the trap up right lessens the chance of escape.. This goes from squirrel to wolf, cougar size animals... Bears require a whole different type equipment and there own unique baiting, capture techniques..
For feral cat, and up to large dog size animals using dog and cat food for bait, put the bait in a cookie sheet, then set the trap over the baited cookie pan.. Be sure to secure the trap to stay upright..
My 5 cents of experience..
/ Live Animal Traps
Thanks for the input. Never thought about the "reaching in and tripping" the trap.
The main problem I have on my property is rabbits. I live in a suburban area so I can't shoot them and a leg trap could harm someones dog or cat, so I am stuck with live traps.
Bell 500 Gallon Saddle Tank (A64119)
Bell 500 Gallon...
3146 (A63117)
3146 (A63117)
2015 John Deere 35G Mini Excavator (A62613)
2015 John Deere...
2012 Freightliner M2106 Bucket Truck, Terex Hi-Ranger HR52M, 52FT Platform Height (A63689)
2012 Freightliner...
Trailmobile Van Trailer (A63689)
Trailmobile Van...
2017 CHEVROLET SILVERADO 2500HD (A65643)
2017 CHEVROLET...
