Joining PVC to CPVC
/ Joining PVC to CPVC #1
rbstern
GA
LS MT225E, Yanmar 2210
I need to tap into a cold water line in my basement for an outside spigot. The line I need to tap is 3/4" CPVC, and I'm attaching it to 1/2" PVC. The outer dimensions of the CPVC are smaller than standard 3/4" PVC, but larger than 1/2" PVC. A typical PVC 3/4" to 1/2" T doesn't fit.
Any suggestions for adapters or techniques, would be appreciated.
/ Joining PVC to CPVC #2
Adapt to 3/4 pipe threads on each and screw together then glue.
/ Joining PVC to CPVC #3
Ok you need to out your 3/4 t in there come out of the t with a short piece of pipe need to use a make adapter threaded and a female adapter to transition from pvc to cove. That should work. Or use a threaded valve and a make adapter on each side.
/ Joining PVC to CPVC #4
Get a glue on threaded fitting for the cpvc and a glue on fitting of the opposite thread for pvc.
D'oh. Standard thread sizes.
Thanks, fellas.
/ Joining PVC to CPVC #6
if you are already using cpvc for cold water why not just stay with it and run your new line the same? just asking.
/ Joining PVC to CPVC #7
Shark bite fittings work great in this case.
Even if I had realized the wrinkle in CPVC to PVC joints without having to ask here, PVC is easier to come by in our local stores, not to mention less expensive. The handful of fittings I needed to tie in were about $6 total. Would have spent signficantly more than that if I did the entire run (about 80 feet) in CPVC.
T fitting is done. Glue is drying now.
Thanks, all, for responding.
/ Joining PVC to CPVC #9
Something not making sense as the OD for all sizes of sch 40 pvc and cpvc are the same regardless of size.
That's what I thought. Not so, and I have the pipe pieces and adapters to prove it. :)
/ Joining PVC to CPVC #11
No they’re not. CPVC and PVC are different diameter and they won’t glue together.
/ Joining PVC to CPVC #12
As a retired pipefitter I can tell you without reservation that the OD's are the same which is why I suggested something is not correct.
Here is a pipe size schedule:
/ Joining PVC to CPVC #13
CPVC comes in both NPS and CTS sizes. CPVC in NPS (nominal pipe size) is the exact same as PVC. This is the most common sizing, however if you have CPVC in CTS (copper tube size) then it will be a different OD than PVC of the same size.
/ Joining PVC to CPVC #14
Yep the CTS plastic is out there and used a lot in manufactured homes where we know they only use the best of the best. I think Sharktooth has adapters for that crap.
/ Joining PVC to CPVC #16
FWIW...for typical plumbing and other industries...the size cited for piping is the inside dia....be it copper, pvc etc., etc...
i.e., 1" PVC is 1" inside and so on...
/ Joining PVC to CPVC #17
Lasco and other PVC fitting manufacturers make a IPS X CTS coupling for this exact scenario. They call it IPS instead of NPS, but same thing. Sharkbite does as well of course but much more expensive.
Couplings are generally available at Home Depot and other similar stores.
Coupling
/ Joining PVC to CPVC #18
You can be wrong if you want to but residential grade pvc and cpvc are 100 percent not the same outside diameter.
/ Joining PVC to CPVC #19
Can us post schedule like I did, would like to see it. Never heard of residential grade unless you are referring to CT size material.
/ Joining PVC to CPVC #20
Here’s a 1/2” and 3/4” pvc and cpvc coupler. They’re not even close to the same.
(6) KUBOTA BRUSH GUARDS (A64280)
(6) KUBOTA BRUSH...
New Landhonor LHR-COA200,  200lb Cast Iron Anvil (A62679)
New Landhonor...
14ft Flatbed Truck Body (A59228)
14ft Flatbed Truck...
2006 Ford F-750 Terex Commander C1017 Digger Derrick Truck (A64194)
2006 Ford F-750...
2021 Tesla Model Y Long Range AWD Sedan (A61574)
2021 Tesla Model Y...
2022 John Deere 7R 210 Tractor (A63111)
2022 John Deere 7R...
