Joining PVC to CPVC
/ Joining PVC to CPVC #21
Here’s a 1/2” and 3/4” pvc and cpvc coupler. They’re not even close to the same. View attachment 710726
Yep it's different because it's Copper tube sized like I mentioned earlier. Horrible to deal with when it's 50 + years old, every piece I ripped out of my house literally exploded in my hands it was so brittle.
/ Joining PVC to CPVC #22
No you said they were the same size and would interchange. They’re not the same size. And I do agree 100 percent that cpvc is trash.
/ Joining PVC to CPVC #23
Not sure you understand, did you even look at the schedule I linked earlier. Standard PVC and CPVC pipe has exactly the same dimensions. your focused on a little used type of cpvc that is based on copper tube size that is no longer used by professionals in new construction.
/ Joining PVC to CPVC #24
Every CPVC I’ve ever seen was smaller outside diameter than pvc. You’re right it’s not used anymore because most people are using pex but you can go down to the hardware store and buy a stick of pvc and a stick of cpvc and they won’t glue together. I looked at your schedule you posted but it’s wrong. CPVC and PVC are different pipes, with different dimensions and they will not interchange. It would be just as logical to discuss gluing pex to pvc.
/ Joining PVC to CPVC #26
He said cpvc was available at his local hardware store.
/ Joining PVC to CPVC #27
The schedule I posted is a national standard for schedule 40 pipe up to 12" and does not matter what material is used (except copper which is only produced as tubing) such as plastic, steel, brass, stainless, and is available on every manufacturers web site.
Yes you are correct the CTS CPVC in that form is not the same as schedule 40.
CPVC is available in many different piping products and systems with the most common being schedule 40
/ Joining PVC to CPVC #28
FWIW...for typical plumbing and other industries...the size cited for piping is the inside dia....be it copper, pvc etc., etc...
i.e., 1" PVC is 1" inside and so on...
Sort of true. Since fittings go on the outside of pipe, the outside diameter becomes the standard even for materials with different wall thicknesses from the original. So 1/2" copper has an inner diameter of 1/2", but plastic pipe made to CTS -- Copper Tube Size -- usually has a smaller inside diameter because it requires a thicker wall to have the same strength.
PVC pipe is made to have the same outside diameter as an iron pipe with an inside diameter of the nominal size, but it will be smaller on the inside because PVC has to be thicker than iron. And PVC comes in different "schedules" or thicknesses so the inside diameter varies. Also, iron pipe today tends to have thinner walls than when the iron pipe standard was created -- they've gotten better at making it. The outside diameter hasn't changed, but the inside diameter is larger.
Next we'll discuss why a 20' piece of pipe is 21' long.
/ Joining PVC to CPVC #29
I don’t know where you came up with schedule 40 cpvc being the most common but it’s not. You’d probably have to go to a specialty plumbing supply to even buy it and I wouldn’t hold your hopes high then. If it’s cpvc and it’s in a house it’s not schedule 40.
/ Joining PVC to CPVC #30
Never said it was the most common in a house, it's the most common produced. I've already stated you were correct with that type of cpvc not being the same diameter so not sure why your continuing to beat the horse.
Can you get a pic of the codes printed on the main water pipe.
No need for me to get on a ladder to take pics. Here are the specs from the Home Depot web site on 3/4" CPVC and PVC:
CPVC outside diameter: 0.875"
PVC outside diameter: 1.05"
/ Joining PVC to CPVC #32
Wow. 30 stupid posts on something that was solved in almost first reply. Then arguement about size. Residential used pvc is schedule 40. cpvc I'm not sure schedule, but it has always been way small. That was done to prevent pvc being used directly against cpvc in hot water installs to prevent failure of pvc. PEX......
2021 JOHN DEERE 844L WHEEL LOADER (A64279)
2021 JOHN DEERE...
New/Unused Landhonor Quick Attach Receiver Hitch Adapter (A65583)
New/Unused...
Informational Lot - Financing (A63689)
Informational Lot...
2010 KMC 3376 Peanut Combine (A61307)
2010 KMC 3376...
2015 IC Corporation PB105 School Bus (A61568)
2015 IC...
213086 (A64276)
213086 (A64276)
