GC Engine Oil Question
/ GC Engine Oil Question #21
Just get the Rotella T6 from Walmart and be done with it. There's even a rebate on Shells website. Under $15 all in. Consider 5w40
Back when I had my 5.9 Cummins, it was Rotella 15W-40 all the way. How we can go from that to "15W-40 is the worst oil you can use [in a diesel??]" is beyond me. Everyone has their opinion, and some lighter synthetic is likely a more engineered oil, but I've never chased the bleeding edge in anything, no need to start now. Cliffy sounds very happy with the 15w-40.
/ GC Engine Oil Question #23
It's whatever you are comfortable with. Most of my hours are blowing snow. No power to the tractor shed for a block heater or battery tender. 0W40 was the easiest to crank in freezing weather, and best IMO for running a 3pt chipper for hours at a time while stationary. Oil chosen for these conditions. Wanted a low pour point with a resistance to high ambient temperatures.
/ GC Engine Oil Question #24
I work the heck out of my GC1720, maxed out snowblowing and heavy loader and digging work. I’ve been using Lubrication Engineers 10W30 Ultra oil. It runs about $25 per gallon which I consider reasonable. Sure Walmart oil may work just as good, who knows, but I’m happy with what I’m using.
/ GC Engine Oil Question #25
It's kind of funny. My first oil change was with Esso XD3 0W40 full synthetic about 2007, it was only available in Canada, at Walmart amongst other places. Priced in line with dino oils. AFAIK they changed the name to Mobil Delvac for North American distribution, using that since.
/ GC Engine Oil Question #26
So I went to local stealer/dealer today to buy filter and engine oil because I was in a hurry and I am way overdue for first 50 hour change. Let me mention that the yard was full of tractors on average probably 30 years old, and none less than 10 years, it seems to be more of a tractor repair than dealer but they are an official MF dealer. I bought out of state near my wife's other house, the tractor goes to both properties, and when he finally called me during my search (after the 3rd message) he said he couldn't get a 1723 so I went to the 3rd closest dealer who had one in stock. Anyway, I like to support local so I plan (or did plan) to take it there for a few services due to warranty. I figured if I bought the oil and filter from him, he'd be easier to work with on service and warranty issues. I tell his counter person I have a 1723E and need filter and oil, out comes 2 gallons of Rotella 15X40. I said "2 gallons? The manual says it takes 2.8 quarts." She says "My boss says to always pull 2 gallons." I pushed back and said the manual says 2.7 quarts, that's a lot different from 2 gallons." She goes to the service area to talk with someone who I think is the boss. She returns and says "He said you should be OK with 1 gallon. He always has me charge 2 gallons" as she pulls one off the counter. So...I am thinking 1) this sounds shady to always charge 2 gallons and 2) 15W40 isn't really the best heading into cooler weather even though in SC it rarely gets below 35 for low temps and it won't be 90 degrees for several months again.
Thoughts?
/ GC Engine Oil Question #27
Are you talking engine oil or hydraulic oil?
/ GC Engine Oil Question #29
Yeah there's some misunderstanding there between the parts girl, you, and service dept. 3qts for engine is what you need. I am in a cold climate and found rotella T6 5w20 the best so far. 15w was too thick in winter, other oils I had to keep topping off, rotella not much top off needed. I'm probably sticking with that
/ GC Engine Oil Question #30
So dudes, you convinced me to switch over to 5w40 for this oil change coming up. So educate this here dummy, what's the downside to 5w40 rotella in summertime, none right? And any issue mixing it with 15w40 I have left over, come next oil change in spring/summer?
Also right quick, are you all changing your coolant every year regardless of hrs put on it? I put in the hd extended life stuff last fall.
/ GC Engine Oil Question #31
OK, I'll admit I'm lazy ... other than coolant losses here & there when I've added, I've never changed my coolant.
/ GC Engine Oil Question #33
5w40 will be the same viscosity at operating temperature as 15w40. It is just thinner at startup.
Coolant is typically good for 6 to 10 years. Ten years on virtually all vehicles now. Next year is the 10th on my diesel generator. Time for coolant and all filter and oil change to 0w30 M1 ESP like is in the JD.
/ GC Engine Oil Question #34
So if I mix those 2 together, do I get 10w40?
I figured it would be overkill changing the coolant after a year...it's not as though I'm on the tractor every day.
/ GC Engine Oil Question #35
Ha-ha! Yes, Ray, you're right -- still going on the original battery! (Hey, I may be cheap... but I'm CHEAP!) :)
/ GC Engine Oil Question #36
Probably. Doesn't mix linearly but won't be too far off.
/ GC Engine Oil Question #39
MF wants the coolant changed annually. Yet, they didn't give you a good way to easily do it.
I really don't see any reason to replace it annually either. Perhaps if you put a ton of hours on it?
My tractor is retired. As in, I put less than 10 hours on it this year. It's really hard to get motivated to do a lot of heavy maintenance with that few hours. I am familiar with the arguments for doing it anyway.
Honestly, I probably won't even change the oil this year.
I'm on Battery number 3.
It STILL has the original fuel filter though!!
/ GC Engine Oil Question #40
I just recently changed the 2025R's fuel filter at the specified 400 hours. Going to multiple years on oil. Went 6 years on coolant. Should have gone 10 like on the Isuzu diesel generator.
Stertil Koni 18000lbs Auto Lift Columns (A61572)
Stertil Koni...
2015 A and A Melters A-110 Towable Hot Rubber Melter (A64553)
2015 A and A...
New/Unused CFG Industrial MX12RX Mini Excavator (A65579)
New/Unused CFG...
Warren Power Systems WCW204MH 20KW Towable Light Tower (A64194)
Warren Power...
2006 FORD F-150 XL TRITON EXT CAB TRUCK (A64276)
2006 FORD F-150 XL...
2023 Kubota L3560 Compact Utility Tractor with LA805 Front Loader (A63689)
2023 Kubota L3560...
