timer on small gas water pump
/ timer on small gas water pump #1
nils gustafson
New Holland 1720, 1951 ford Jubilee ,1968 JD 110 mower
would like to put a timer on my 5hp Honda water pump . Have a late night water schedule ,and have been just letting the gas run out ,but don't like the pump recycling when running out of gas. Does have an on off switch that I could wire up to this mechanical timer . The on off switch is hooked up to the low oil sensor so i have to look at it closer .. Any other ideas would be appreciated .. need my sleep 🥱 thk/u.gus.
/ timer on small gas water pump #2
I don't see why not, just replace the on off with the timer. Keep the low oil switch intact.
/ timer on small gas water pump #3
I think you're going to find the spring timer is N/O and biased closed when the spring is wound. In other words the timer, when at zero minutes is an open circuit and is a closed circuit when it has time left on the dial.
A small engine is usually an open ignition circuit and shorted out to ground when it's shut off killing the spark, opposite of the spring switch............Mike
wow something to consider, glad I posted ,back to thoughts, thanks..
unfortunately ,no .. but I would like to know your solution if there was ?
thk/u. for reply ,gus..
/ timer on small gas water pump #7
Electronics really isn’t my thing so I’m not sure about the process but it can be reversed with a relay.
/ timer on small gas water pump #8
OK this may take a bit of work on your part.
First, what is the brand, make, model and part number of your engine ?
Second, do you know if there is a fuel anti-backfire solenoid on that engine ?
Richard
Honda water pump, WB20X/ model GX120T1, didn't see any BF solenoid on a parts list on line. thanks for your time, gus.
/ timer on small gas water pump #10
OK found a spring powered timer that has a SPDT (Single Pole Double Throw) switch. In the Jpeg below,it's called a 3-way switch.
Here are the choices as far as set time. You have your choice of a timer with a hold function and timer or just the timer function.
Here is the link to where I found this. You may find other sellers with a search for the timer you want:
You would want to wire the on/off switch on your engine so that one of the wires goes to the timer switch. I have not looked up you engine yet, but it should be clear what wire to use when you see how the on/off switch is wired.
You will want to put the timer in a weather proof box of some sort.
Richard
I am not a good "sparky" , I think I understand SPDT ,so middle is off ? and if I wire to load #1 and click sw to #1 start timer then when time is 0 the sw is open and grounds out spark plug? thk/u, gus..
/ timer on small gas water pump #12
Have you considered reversing the operation so that when the switch is ON the pump is OFF
/ timer on small gas water pump #13
The best way for you to see how this would work is to buy one of these timers and then play with it a bit.
Do you have a volt/ohm meter ? If not, you will need one to see that operation of the switch.
There is no "middle" position. The terminals are NO (normally Open) and NC (Normally Closed) In this illustration above, the input terminal is in contact with the top terminal, so that would be the NC connection.
In your application, you would connect the input terminal to the wire that goes to your engine on/off switch. You can leave the engine on/off switch wired as is, just connect the input terminal to the same wire.
Then the bottom terminal would be connected to the engine ground.
When you set the timer, lets say for an hour, when the hour is up, the contact will switch to the NO terminal and stop the engine.
This should give you and idea on how to wire up the timer.
Richard
On order, will play with my volt meter, and build W/P box. thanks for all info ,will report , thk/u, gus..
Got a SPDT timer..Might be wiring up wrong , got the V/M on buzzer
Richard
Got the SPDT timer ; Might have it wired wrong , have V/M set on buzzer, (Red on line 1) (black on NO ) as shown when timer goes 0 no buzz ? any sugg. thk/u, gus..
/ timer on small gas water pump #16
OK I'm not sure why you are using the diode test feature of your meter for this experiment.
Set your meter to the ohms position and to the lowest ohm number. On your meter, that would be the 200 position. After switching the meter to the 200 ohm position, short your meter leads together to see what kind of reading you would expect when the switch makes the connection during your test.
I also don't know how you have determined which terminal is NO and NC.
What model switch did you buy?
Model is Tork , (attachment instr.) wired up (instr, are noted NC-NO ) still when timer goes 0 no Ohm reading as noted when shorted ?
Also Why won't buzzer on meter activate on test? thk/u. gus..
/ timer on small gas water pump #19
Try this, with the timer is at zero time, set your meter to the 200 ohm position, with one meter probe connected to the Line 1 terminal, then touch the other probe to the to the load 1 terminal and then touch the probe to the load 2 terminal. One of those terminals will result in an open condition, i.e. no reading on the meter.
Do you have a friend or a co-worker who can help you with this ?
Richard
Richard
Yes ,Load 2 has a reading , load 1 no reading- open. thk/u
2016 Ford F-150 4x4 Crew Cab Pickup Truck (A64556)
2016 Ford F-150...
New/Unused Wolverine 3 Point Hitch Attachment (A65583)
New/Unused...
2005 International School Bus (A64194)
2005 International...
2002 Ford F-250 Service Truck, VIN # 1FTNF21L52EB33349 (A65563)
2002 Ford F-250...
2022 Mack Pinnacle T/A Day Cab Truck Tractor (A64556)
2022 Mack Pinnacle...
New/Unused ATS EPC40 Plasma Cutter (A65583)
New/Unused ATS...
