bobcat 325 excavator drive/swing problem
/ bobcat 325 excavator drive/swing problem #1
ROUSTABOUT
Elite Member
Luther Willis Hill, AR
Pettibone, Ford, Massey Ferguson, International, JD, David Bradley, home mades
Hello, I have a 325 excavator and was working fine then, the left track doesn't pull, I can still drive it to move it by driving and steering with the right side. Also, the swing will not go to the left. Swing right is fine. So, I have a chain connected from the left of blade to the bucket, just so I can move it around if I need to. Engine cranks and runs well. Digs fine, has plenty of power. I checked fuses and relays. I swapped the electromagnetic coils under driver side foot board. If anyone has run into this problem, so advice will be greatly appreciated. I have read a lot on the forums and have learned so much and gotten some good ideas too. Thanks
I figgered it out. Pulled out the swivel joint and re did it. Way down in the bottom in the center. But, that did it.
/ bobcat 325 excavator drive/swing problem #3
Great you were able to tackle that. I Just bought same model just a few months ago, will be using it when weather gets better.
/ bobcat 325 excavator drive/swing problem #4
ROUSTABOUT glad to hear also you fiquered it out and repaired it . Just wondering ??? ..... how come it took 11 years to let us know ??? 🧐
1024 (A63111)
1024 (A63111)
2016 CATERPILLAR 416F2 BACKHOE (A62129)
2016 CATERPILLAR...
Black Jet Dock Drive-On (A59228)
Black Jet Dock...
2009 Kubota M108S (A60462)
2009 Kubota M108S...
PALLET OF MISC METAL (A63291)
PALLET OF MISC...
LILLISTON 8R ROLLING CULTIVATOR (A63291)
LILLISTON 8R...
