SA424 with skid steer quick attach
/ SA424 with skid steer quick attach #1
REMc
None
I want to purchase a compact tractor around 25 HP with larger tires. The SA424 is EXACTLY what I would like to purchase except for one thing, it does not come with skid steer quick attach on the front end loader. Many other manufactures (Kubota and Massey Ferguson just to name two) make a 25 HP tractor with larger tires and have skid steer quick attach on their front end loader. The YT235 comes with skid steer quick attach. According to what I have read, the difference in front end loader lift capacity between the YT235 and SA424 is only 100 LBS. I do not understand why Yanmar does not offer skid steer quick attach on the SA424. In my opinion they would sell more SA324 and SA424 tractors if they offered skid steer quick attach on the front end loader. It will probably be about one year before I purchase a tractor, but if the SA424 came with skid steer quick attach, I would not be looking at other tractor manufacturers, I would be buying a SA424.
I know I could buy/make a plate that would convert from the Yanmar quick attach to the skid steer quick attach but that is an extra cost and I am also loosing front end lift capacity because of both the weight of the plate and the distance/length of the front end loader has now increased which decreases lift.
Am I the only one who feels this way?
/ SA424 with skid steer quick attach #2
Check this out!
willy
/ SA424 with skid steer quick attach #3
Simply put "weight", I was told by a regional Yanmar guy at the Outdoors show in Harrisburg PA a few years ago. Yanmar would need to lower the published FEL lift capacity rating by a couple of pounds and thus lose the marketing wars.
/ SA424 with skid steer quick attach #4
Wow, I didn't realize the SA324/424 doesn't come with skid-steer quick attach. Some of the statements in their advertising imply that it does, like this one attached below. So what exactly do they mean by "YANMAR quick attachment system"? And how long does it take to switch from, say, bucket to pallet forks? Thanks for bringing this up. I've been evaluating the SA324 vs. the new LS MT225S and I did not realize the difference wrt this feature.
/ SA424 with skid steer quick attach #5
It says "Yanmar" quick attach system. They must have their own so you have to buy their attachments. That would certainly be a deal breaker for me. That's why I would never buy a JD either.
On a side note; SSQA compatible attachment panels and latches are available. You just have to custom build the fixture to attach the latches to the tractor. That's what I did.
/ SA424 with skid steer quick attach #6
I can confirm that the Yanmar quick attach system is unique to the SA series of Yanmar tractors. I had the bucket off of mine yesterday to add some grab hooks and support gussets. Attach/removal is quick, easy, and can be done in less than 60 seconds if everything lines up on the first go.
As I'm currently looking for more attachements (especially with no Yanmar dealer near me), a universal attachment system would be a giant advantage in the long run. I'm considering a conversion of some sort myself.
There are a number of options ranging from "fabricate an adapter yourself (from parts)" to just one off-the-shelf solution that I could find.
- Fabrication option: It is possible to purchase Yanmar-SA-specific brackets online as well as the required SSQA hardware. There would likely need to be modification all around to join the two properly. This solution would result in an Yanmar-to-SSQA adapter much like Williy's video shows.
- Off-the-shelf option: I found a company that manufactures a full conversion kit. From what I can see this is the best way to do it as it replaces the pin-on portion of the Yanmar quick attach system with a pin-on SSQA system. The downside side is, of course, the price. (Tach-All Quick Attach, Loader Attachments, ATI Corporation - Google for "ATI QA-YA5")
I suspect it would be cheaper for the first option, but the pin-on option would likely be more robust and integrate best with the tractor.
A third option (the one I personally am considering first for a conversion of my own) is to modify the factory Yanmar pin-on brackets with SSQA hardware. If you plan to go "all in" on SSQA from day one, the factory equipment is of little use to you so modifying it is the cheapest option and, in my opinion, closest to the "off-the-shelf" solution proposed above. I'm certain this option would adversely affect the loader warranty, though.
It sounds like you're already sold on the Yanmar SA series aside from the attachment mechanism. For what it's worth, I love my SA324 and use it all the time. It hasn't yet let me down and it's capabilities never cease to amaze. I also have a John Deere 4400 with 430 loader that, I'd say, is about a "size up" from the SA424. That tractor rarely gets used because the Yanmar is perfect for my day-to-day use cases.
Good luck and keep us in the loop!
/ SA424 with skid steer quick attach #7
It's not too bad. I switch between bucket and forks regularly on my 424. Lift up whatever's attached, tilt it slightly forward, then for each side pull a cotter pin and pull the big pin out. Then set the attachment on the ground and drive over to the other one and line up the top hooks. If you drop them on level ground it's no big deal to line it up. Then you put the pins back in. It takes a couple of minutes tops.
/ SA424 with skid steer quick attach #8
This is all great info. Maybe I'll just fork out (pun intended) for the Yanmar pallet forks, and use the Yanmar system as intended. I'm guessing that saves a few pounds on the FEL, which was their reason for doing this on the subcompacts. I'm sure their reason was not to squeeze a thousand dollars out of me for the pallet forks.
Yes, I'm just about sold on the SA324. The other tractor I'm considering is the LS MT225S which looks pretty nice also. But I think the Yanmar dealer location might sway me. Just 3 miles away, down country roads that I could drive on the tractor, assuming it is drivable. LS is 40 miles away and I don't have a trailer.
Anyway, thanks! It's great when a forum really works. I'll report back when the deed is done.
/ SA424 with skid steer quick attach #9
If you want that type of bucket attachment just get the YT235
give it a test drive I believe you will really enjoy using this
great tractor. Compare the two tractors and see the difference
if features. The B75 backhoe is really a great attachment a lot
stronger than what's on the SA324 or SA424. If you add the
skid steer attachment more weight drops lifting capacity and
then you have the cost.
wlly
/ SA424 with skid steer quick attach #10
I thought seriously about the YT235. But the dealers seem to be out of everything >25 hp, and they don't know when they will get them. Tire shortages and other problems are affecting many brands, but 25 hp and below are available. Also, the cost difference between 25 and 35 hp is big, like 50% greater for Yanmar. Plus my wife needs to be comfortable with it. And when I remember how much good work we got out of our little 18 hp Yanmar 2wd grey-market tractor years ago, I'm thinking the SA324 will be a dream in comparison. And a dealer quoted me $14,750 after cash rebate and military discount for the SA324 w/FEL, so I'm having a hard time finding reasons not to go and grab it.
/ SA424 with skid steer quick attach #11
Here's something to consider about the likely lowered lift rating if you convert to an SSQA setup on an SA324...
I just reviewed the loader specifications (LL2300) for the LS MT225S you mentioned. Speaking *strictly* from a lifting capacity perspective, converting an SA324 to SSQA (with whatever weight that adds) may actually make the two tractor loaders nearly equal (SA324: 1,199lbs versus MT225S: 1,067lbs [all weights at pivot pins]).
I'll readily admit that proximity to a Yanmar dealer (< 3 miles), a loader capacity of 1,199lbs, and knowing the Yanmar name from childhood (we had a 240d) were the driving factors for my choice.
However, the overall specifications on the LL2300 suggest it is an ever-so-slightly larger (and dare I say better?) loader. It lifts a little higher, digs a little deeper, has a touch higher breakout force, slightly better dump/rollback angles, etc. It also includes SSQA capabilities.
I know that I use the loader for most jobs I do around my property where the tractor is involved. Loader capabilities were at the tippy-top of my requirements list. That being said, the MT225S with the LL2300 loader looks to be a slightly more capable machine on paper. Heck, another advantage for the LS is that it even has a Yanmar motor!
You'll know more about how pricing stacks up and what works for your situation, but in the spirit of being unbiased and looking for the best overall value, I think the LS has its merits and deserves fair consideration. I have no regrets about my choice, but If I were in the market and had Yanmar and LS dealers near me... it would be a tough decision.
/ SA424 with skid steer quick attach #12
My pallet forks are from Earth & Turf Attachments. They are a few hundred dollars cheaper than the Yanmar ones and fit the Yanmar QA system just like the bucket. I haven't used the Yanmar forks so I don't know if there are any functional differences, but the E&T unit has worked well for me.
Under $15k sounds like a great price to me. I paid over $25k for a 424 with backhoe last year. I'm sure I didn't get a great bargain but it was on the lot and the dealer is local & well-respected. I've been very happy with the tractor, the only drawbacks I see with it are the much smaller aftermarket and lack of online info vs Kubota or JD.
/ SA424 with skid steer quick attach #13
Well, I bought a SA324 on Saturday. It'll be delivered in a couple of days. I'm reading through the operation manual and I've got some questions which I may post on the forum, if I can't find the answers there already.
sa324owner:
I first drove the LS MT225S before I went to the Yanmar dealer. It was pretty nice, but there were a couple of frustrating things. Like, the parking brake would pop off on it's own, at least half the time. And it was extraordinarily hard to shift the drive system into the desired range (low, medium, or high). I found that if I stopped fighting it, then touched the fwd or reverse pedal just slightly, and then stopped and reattempted to shift, it would usually work. Afterwards, the mechanic told me it was because it was brand new that it was doing that, and also that I need to be in idle to shift. I'm new to HST tractors so I wasn't sure what to think about that.
But the SA324 had no issues like that. Everything worked the way you would think it would. Somehow, the design struck me as a little more refined also, but I can't put my finger on why. The one thing I didn't like about the 324 was the groaning from the HST while driving. It seemed louder and more annoying than the LS, almost cringe-worthy. Also, stopping the tractor may have been slightly more abrupt, even when trying to be smooth on the pedals. The dealer rep (who owns a 424 of his own) said they all sound like that. I hope I can get used to it.
Overall I was happy with the Yanmar and I was surprised that the price came in about $1500 less than the LS. Considering the tractors are very similar, I would have guessed it would be the other way around. Also, having a Yanmar dealer only 3 miles from home was a major factor for me.
ultrameta:
I just ordered the pallet forks from Earth and Turf. They were about $300 less than the Yanmar forks, even after shipping. And the company was responsive and knowledgeable. Thanks for the tip! Between the forks and bucket I should have all I need, without converting to SSQA.
/ SA424 with skid steer quick attach #14
The SA transmission is a little loud. Over time it has gotten quieter or I have gotten used to it. I believe that you have made a good decision in choosing the SA over the LS. Congrats on the tractor.
/ SA424 with skid steer quick attach #15
sa324owner:
ultrameta:
My 424 transmission is pretty quiet. Don't know why mine is different than most everyone else's but I'm glad it is!!
/ SA424 with skid steer quick attach #16
Get a headset to knock out the noise
or one with a radio etc.
My is loud but I don't care it does what I
want! I like the way the tractor stops when
you take your foot off the forward pedal!
willy
/ SA424 with skid steer quick attach #17
I took delivery of the tractor a few days ago. It took me about ten minutes to get over the HST noise!
/ SA424 with skid steer quick attach #19
Actually... I have a question for you. What is that foot lever I've circled in the attached picture?
Having intimate knowledge of the differential lock linkage on these tractors, that's my off-the-cuff guess. If so, that sure beats the way they used to do it!
2015 GMC 3500HD Flatbed Truck  6.6L Duramax Diesel (A63688)
2015 GMC 3500HD...
Caterpillar 322B/ 322BL Excavator Service and Parts Manuals (A63117)
Caterpillar 322B/...
JOHN DEERE 4560 TRACTOR (A64280)
JOHN DEERE 4560...
John Deere TX Gator (A60462)
John Deere TX...
2014 FREIGHTLINER COLUMBIA GLIDER 6X4 T/A SLEEPER TRUCK TRACTOR (A59911)
2014 FREIGHTLINER...
2014 Volvo Sleeper Tractor (A62679)
2014 Volvo Sleeper...
