3 Sided Equipment Storage
/ 3 Sided Equipment Storage #1
LittleBittyBigJohn
Central Arkansas
John Deere 1025R, Kubota ZD1211
I'm just about to be in need of an equipment shed. Need to store mowers, gas cans, hand tools, tractor later this year hopefully, etc. I would like to make it maybe 20X30 so I would have 3 bays for storage dirt floor is fine. I don't want to spend a fortune on it but I would like it to last a good long time. Eventually I am going to build a large shop so this may turn in to a barn for animals.
Do you have any insight on the best way to go about that?
/ 3 Sided Equipment Storage #3
6" to 8" posts. 2 x 6 framing.
Metal sides and roof
Find your prevailing wind direction (where your most frequent and strongest winds usually come from) and set the open side away from that.
Depending on lumber and metal prices, you might get 20 x 30 for $1500-2000 doing the work yourself.
/ 3 Sided Equipment Storage #4
3-sided is great storage for anything that won't walk off. Build it as tall as you can to allow for hay storage. That extra 4' of wall metal is cheap.
/ 3 Sided Equipment Storage #6
I have five carport bays where I store my stuff. Riding mowers, tractor, ATV and any implements with moving parts ( Wally chipper ). The remaining implements are each stored out in the old orchard - each on its own pallet. My main objective is to get this stuff out of the sun. Around here the sun will create the most damage to my equipment.
/ 3 Sided Equipment Storage #7
Not in my area. $1500 is not going to go far.
6x6x12's are $45, 6x6x16"s are $52
/ 3 Sided Equipment Storage #8
Wow, that's like 1/4 or a bit more then what it's going for here. I recently called to price some wood and decided that I can do without what I wanted to build for a while.
/ 3 Sided Equipment Storage #9
I have been doing some interesting construction projects from piles of scrap. It turns out those leftover boards can be useful if I can't run to the lumber yard for a cheap 2x6.
/ 3 Sided Equipment Storage #10
I do try to reclaim everything when I tear something down, which is one of the reasons I don't use screws, and nails are cheaper. I used 50 to 60% of the wood out of my old shed to build my new one. I also bought the wood for that early last year before the madness had begun. There is no such thing as scrap wood unless it's started to rot. I can always find a use for it.
/ 3 Sided Equipment Storage #11
I bought a Carolina Carports barn in early covid before shortages and price increases. 31x42 with 9' and 14' sides. I got the 12 gauge frame upgrade that is supposed to be Florida rated for 170 MPH winds. May 2020 was $11,380 not including ground prep. I have $800 or $900 in fill and crushed red brick under it.
Center section is 18' wide and sides are 12'.
/ 3 Sided Equipment Storage #12
If you have enough room least make entrance drive thru opening.
2013 KENWORTH T800 DAYCAB BOBTAIL VAC TRUCK (A65643)
2013 KENWORTH T800...
2001 KENWORTH W900 72" STUDIO SLEEPER (A62613)
2001 KENWORTH W900...
2016 KUBOTA SVL90-2 SKID STEER (A65053)
2016 KUBOTA...
2007 Mack CV713 Granite T/A Pole Truck (A62679)
2007 Mack CV713...
2001 INT 4900 DT 530 (A62679)
2001 INT 4900 DT...
County Line 4' 3Pt Mower (A66408)
County Line 4' 3Pt...
