npalen
Elite Member
Here's the issue: My Sister in Law's automatic sprinkler system has one zone with too many sprinkler heads to operate at one time so it has two ball valves that have to be manually switched to do half at a time. The ideal solution, of course, would be to install another solenoid valve but the distance is quite a ways from the controller to run the control wire.
The shuttle valve shown above is what could be used except it it designed to COMBINE two inputs into one output. I need a solution that does just the opposite. It would need to direct the pump flow to one side of the tee for watering half of the zone and then to the other side to water the rest of the zone. It would automatically switch to the other outlet of the tee when the upstream solenoid switches off and relieves pressure. Then the rest of the sprinklers on that zone would be watered and the process repeated for the next watering cycle.
I know it's a long shot but wondering if such a valve exists or whether something similar could be cobbled to achieve the desired results. TIA.
