ruffdog
Super Star Member
- Joined
- Dec 31, 2011
- Messages
- 12,528
- Location
- America's Dairyland
- Tractor
- Bobcat Toolcat 5610G, Deere X744, Cub Cadet IH 982
Wow....500 less engine RPM than what it was designed for is a huge drop in mower blade tip speed.
Since the belly pto operates over 2000rpm a 500rpm drop could mean 1000rpm less blade tip speed.Wow....500 less engine RPM than what it was designed for is a huge drop in mower blade tip speed.
I can visualize putting the mower blades on upside down by mistake, but how do you put one on backwards?
Wouldn't it either be "right side up", or "upside down"?
Deere makes marine diesel engines (stay with me folks, you'll see the tie in to tractors). They rate those engines in 5 gradients, using a rating system of M1 to M5:"Every mower I've ever had except for REAR PTO driven mowers has been run at WIDE OPEN THROTTLE.
Push mowers, cheap riding mowers, tractors with belly mowers -- always run wide open.
Does anyone have a push mower that they don't run at WOT? Why would a belly mower be any different?
My RC72-27B (72") mower cuts really slick running at WOT. It would do a lousy / ragged job at 2100 RPMs.
| M Rating | Typical Load Factor | Typical Annual Useage | Typical Full Power Operation |
| M5 | ≤ 35% | ≤ 300 hr | 0.5 of each 8 hr |
| M4 | ≤ 40% | ≤ 800 hr | 1 of each 12 hr |
| M3 | ≤ 50% | ≤ 2000 hr | 4 of each 12 hr |
| M2 | ≤ 65% | ≤ 3000 hr | 16 of each 24 hr |
| M1 | > 65% | > 3000 | Uninterrupted |
In this system, M5 points to engines for recreational cruising boats. The manufacturer is telling us that the M5-rated engines will maximize longevity when those three parameters are met."
M Rating Typical Load Factor Typical Annual Useage Typical Full Power Operation M5 ≤ 35% ≤ 300 hr 0.5 of each 8 hr M4 ≤ 40% ≤ 800 hr 1 of each 12 hr M3 ≤ 50% ≤ 2000 hr 4 of each 12 hr M2 ≤ 65% ≤ 3000 hr 16 of each 24 hr M1 > 65% > 3000 Uninterrupted
Absent particulars from the tractor engine manufacturer, I'd be hesitant to subject my CUT, or SCUT to "full power operation" any more than 25% of the time.
Agreed. But . . . How do you get more power if you're running at WOT ?WOT and maximum power aren’t the same thing.
You can certainly be running at WOT and not be under a full load. In fact, when sitting still and just spinning the blades at WOT, the tractor is under very little load.
I don't understand the reluctance to run the tractor at the proper RPM for PTO work. It's clearly indicated on the tachometer. Based on the manual I downloaded, proper RPM for mowing on that tractor is 2800 RPM. If you were running a tiller or bush hog, the proper RPM would be 2800.
Take it to the dealer and mow some grass in front of their place and ask them what's wrong. I bet $5 they point to the hashmark on the tach and tell you to increase RPMs to 2800.
It's always a good idea to have sharp blades, but it's still not going to cut right at 2300 RPM. That's like taking a basic push mower and running it at 75% of its rated RPM speed. It just won't do a smooth job.
I looked at my Kubota manual for both the rear and mid PTO. For both, Kubota says to run the engine at the speed indicated on the tach. (In my case, that's approx. 2600.) There's no mention of NOT running at WOT and there's also no indication of a "red line" on my tach. WOT on mine is 2800 RPM with NO load on it.
Good luck.
It’s pretty common for people to think they’re “saving” the machine by running it slower. How they come to that conclusion I’m not sure.
Agreed.
Consider any zero-turn mower, just as an example. Whether gas or diesel, a ZT is going to run at WOT almost all the time. I'd guess that mine runs 95% + of the time at WOT cause I only back it down when I'm getting ready to mow or finishing up and putting it away. For the several hours that I'm mowing, it's all WOT.
There's no tach on mine either. Just bury the throttle and mow. Just like every other lawn mower . . .
Never really gave it a thought till now. Now my head hurts . . . ;-)
Mike -- take it out and mow with it at 2800 RPM for 10 minutes and see if it doesn't do a good job. Even dull blades will cut grass when you spin them at the right speed. They'll tear the grass instead of cutting it clean, but it will be shorter and it will throw the clippings like it's supposed to.
Good luck with it!
Sharp blades and running it at WOT (2800 in your case), and that mower will cut like it's designed to.OK, took the belly mower off the tractor, put a couple of chains on it and lifted it vertical so I could get at it using the FEL. (Safety blocked as well, it weighs 300 lbs.)
No crud accumulated under the deck.
Belt appears OK, not glazed or cracked.
Blades installed by dealer or factory so they are right side up, but see below. (Note that dealer setup was "indifferent", I've had to correct a few things here and there. That's what I get for reading instructions and manuals.)
Blades not bent, but VERY, VERY dull, these desperately need to be sharpened.
There's a flat metal plate bolted to the leading edge of the deck, one on the left side, there are holes in the deck for one on the right (discharge side). The left one is present, the right one appears to never have been installed. The plates extend back horizontally from the lip on the deck back perhaps an inch on the left side, no idea on the right side because it just isn't there and I've never seen it.
No marks showing if it was torn off or fell off, paint is undisturbed. I *know* if it came off while I was mowing, it would have made a heck of a racket, in fact, the equivalent plate on my riding mower HAS come off (twice, vibrated apart) and stopped the mower dead each time.
So here's the plan:
1) sharpen and balance the blades
2) determine if the baffle plate is missing, if so, buy and replace (with hardware, three carriage bolts and nuts)
3) clean everything, inspect everything, lube everything. Easy when it is off the tractor, not so easy when it is on.
3) run at higher tach speeds, probably 2,300 or so. (I have to adjust the throttle friction washer, the RPM likes to slowly drop to about 2,000 to 2,100 RPM if I don't hold the throttle open.)
This will probably happen this coming week, so stay tuned!
Best Regards,
Mike/Florida
In this case, the D1105 is rated at different engine speeds for various equipment. The highest rpm I've seen the particular engine rated to is 3200. Just because 2800 is the max in this application doesn't mean it's the max engine speed for the engine.Agreed. But . . . How do you get more power if you're running at WOT ?
