Electric conversion of a Kubota B26 / Similar
   / Electric conversion of a Kubota B26 / Similar #51
Then again the generator would not work
and the cost is high also. The really best
solution is repair the engine you have or
get a new one! Less hassle, easy fix and
you won't strain your brain trying to figure
out on what to use in place of your diesel
engine!
willy
Somethings are done just because someone wants to do it.
"The Solution" being sought is to build a battery powered electric tractor.
Hats off to the OP for being creative!
   / Electric conversion of a Kubota B26 / Similar #52
This thread is definitely going in some very interesting directions! So far we have a Kubota tractor powered by an array of ebike batteries, supported by a trailer mounted generator (Yanmar, no less) and a really long power cord. Hydraulic accumulators and other exotica are also in there somewhere. It can only get better from there!
Galstaf, if you are needing a tractor sometime in the near future, electrifying this poor little orange thing may not be the quickest or cheapest way to get your wheels turning, but it sure will be the most challenging and entertaining! But if you're considering it karma that you have this B26 and all those lithium cells, well maybe this is meant to be. A word of caution: please don't plunge ahead thinking this will be any easy challenge. There is a lot involved here and this may have to be done in stages. I really hope you press on!
   / Electric conversion of a Kubota B26 / Similar #53
If you really want to build an electric tractor
Monarch tractors they purchase bare tractor
with no power so they can build up. Perhaps
if you can find a parts list for an electric tractor
it would help you to get the parts that you need
for your tractor and maybe help you figure out
if its feasible to go electric.
willy
   / Electric conversion of a Kubota B26 / Similar #55
He's talking diesel-electric hybrid.
No he’s not because he suggested leaving the battery off and just using generator power. A tractor isn’t a good potential for a hybrid. For one the fuel bill of a 20 hp tractor is so insignificant it’s not worth worrying about. For 2 a machine that’s running at continuous output has very little potential for savings being a hybrid. It doesn’t take much power to maintain cruising speed on a vehicle and you can save energy by running the generator at its most efficient rpm range and turning it off when it’s not needed.
   / Electric conversion of a Kubota B26 / Similar #56
Ok, then just diesel-electric. Simple concept using DC motor and generator. Speed and power are directly related to engine RPM up to governed speed.
   / Electric conversion of a Kubota B26 / Similar #57
You’d have to totally strip the tractor transmission and put the electric motors to the wheels to gain anything. A diesel electric to drive a HST trans is not only pointless it’s a step down in efficiency. You’re still burning diesel and you’re still making noise. The only thing you’ve accomplished is wasting a bunch of money, cobbled up your tractor, and made it less reliable than it was to start with.
   / Electric conversion of a Kubota B26 / Similar #58
Here is an idea, rebuild or get a different engine, put an alternator on it, then that charges a 12 volt battery that powers the starter and the lights.
I realize people are just thinking out loud but……..
   / Electric conversion of a Kubota B26 / Similar #59
A little info about an electric tractor that takes the
place of a 40 hp diesel tractor????
Base Price: $45,999 USD
Front Loader: $9,999
Exchangeable Battery Pack: $9,999
Front Hitch: $4,999
Auxiliary Hydraulics: $4,999
The price is approx $80,000 taxes, fees
etc. then you need attachments to work with??
MORE MONEY??????????
willy
If this was my tractor I would repair the diesel
   / Electric conversion of a Kubota B26 / Similar #60
Sad to see that all the OP asked for, was some tips or ideas on the best way to tackle this post. Instead, all he got was a bunch of naysayers.
He didn't ask for money to be able to fund this project either, so not sure why people try to tell the OP how expensive or not this project can get, which, I'm sure he already know plenty about that.
The OP referred he has the batteries already, which is a big step ahead on this project. He also mentioned that he only needs to use the tractor a couple hours a day. He is not going to do commercial work, doing 8 to 12 hours shifts.
To the OP, hopefully you'll get the project going to suit your needs and please, post updates if you choose to do so.
Toyota 7FDKU40 7,350lb Forklift (A55973)
Toyota 7FDKU40...
2014 DRAGON 130 BBL VACUUM TRAILER (A58214)
2014 DRAGON 130...
Club Car Electric Utility Cart (A55853)
Club Car Electric...
2003 International 4300 Cab and Chassis Truck (A55852)
2003 International...
1997 Ford E-250 Cargo Van (A56858)
1997 Ford E-250...
SKIDDED FRAC TANK (A55745)
SKIDDED FRAC TANK...
