Loader GC2310 FEL very weak
   / GC2310 FEL very weak #71
Hello sir, running into similar issues seems like hydraulic oil over heating after running for a bit.. any advice, updates on your experience? Thank you so much!
He hasn't posted in 4 years, so he probably won't see this.
Try sending him a PM, (private message), that should go to his e-mail.
You can click on his name badge for that option.
   / GC2310 FEL very weak #72
I got the pump yesterday.
The good news: I'm now 99% sure my pump was the issue. I can hardly blow air through the pump at all. The old pump was nearly free flowing.
The bad news: The shaft is exactly the same length.
The so-so news: After more inspection, the spines in the gear side are really in perfect shape. The splines on the old pump look a little bit fatigued. So maybe the assembly will be like new, as good as that is.
I've tried to think of a way to extend the shaft or add a coupling/collar and attach it to the gear, but I think any effort there would likely end up being nearly as difficult as changing the gear.
I installed most of it last night and will finish up once it stops raining.
Hello sir, been a long time for this
Thanks!
2023 TAKE 3 TRAILER 3 CAR TRAILER (A52141)
2023 TAKE 3...
Hayrack (A50515)
Hayrack (A50515)
2021 CATERPILLAR D3 LGP CRAWLER DOZER (A51242)
2021 CATERPILLAR...
2014 Caterpillar 257D Compact Track Loader Skid Steer (A50322)
2014 Caterpillar...
EZ-GO Electric Golf Cart (A50324)
EZ-GO Electric...
1266 (A50490)
1266 (A50490)
