Side mounted fire starter. Red Hot exhaust
/ Side mounted fire starter. Red Hot exhaust #1
Goose1776
Gold Member
Massey 2706e
Looking through old posts, seems to indicate this is “normal” for the Kohler powered 425???
Nope don’t like it…
About gave me a heart attack when I was mowing tonight.
/ Side mounted fire starter. Red Hot exhaust #2
I don't know anything about the PT machines but ain’t nothing normal about that picture! Holy Cow!
Yeah
I don’t think so either
/ Side mounted fire starter. Red Hot exhaust #4
I do like the fact it has the word HOT on top. Pretty sure if this is normal that would be self explanatory. :ROFLMAO:
/ Side mounted fire starter. Red Hot exhaust #5
:oops:
I should’ve thrown a steak on there
/ Side mounted fire starter. Red Hot exhaust #7
If that is a low light picture, it is normal for gasoline engine working at max HP, if that is taken in sunlight, it is not so good.
It was low light, almost dark
Only reason, it looks more like daylight, is I was under a dusk-dawn light when I took the pic
It still doesn’t seem right, lol
but engine is brand new,
starts, and runs fine, with no loss of power, no misses, backfires Etc.
/ Side mounted fire starter. Red Hot exhaust #9
Retarded ignition will run a red hot exhaust. But there will be other symptoms, like power loss.
These new fangled CCD pocket cameras screw up picture taking big time. Auto exposure on one aspect makes an adjacent detail all color crooked.
Here’s a pic in the dark, when I pulled into the shed
/ Side mounted fire starter. Red Hot exhaust #12
My PT180 does the same thing without full throttle. Think of the funny cars at the dragway with the open header single exhaust and you see fire coming out of each pipe.
/ Side mounted fire starter. Red Hot exhaust #13
I don't have a 425, but this has been a long standing issue. I would through the older threads, if you want to see more examples, and causes/solutions. One user posted a cut open muffler, which may give you some insights.
Overheated Robin EH72-FI (28 hp) in PT-425 solved
In my completely inexperienced couch potato eyes, it looks to me like the muffler is too restrictive. Several users have put on different headers and mufflers and the problem has gone away.
I would also observe that slight differences in fuel/air ratios, timing, and octane levels can have a big impact on secondary combustion in exhaust headers and mufflers.
All the best,
Peter
/ Side mounted fire starter. Red Hot exhaust #14
There's also excess heat in the tub. I added a fan (like the cooler fan) to the side. Helps.
I will probably end up doing that as well
/ Side mounted fire starter. Red Hot exhaust #16
Playing around with ignition timing would be worth the effort.
If these solid state ignition systems didn't make it so difficult.
Just getting to the points on the K582 is an exercise in sheet metal handling.
/ Side mounted fire starter. Red Hot exhaust #17
You might note that many chain saws incorporate spark arresters since apparently they are a source of fire starters.
Could be California missed including some categories of engine powered equipment.
/ Side mounted fire starter. Red Hot exhaust #19
Make sure you have the right spark plug in it my friend had the same problem and he had the wrong spark plug
/ Side mounted fire starter. Red Hot exhaust #20
I suspect a timing issue. But if they told me that was normal I would be getting something else. I also can not imagine any manufacturers that would want the liability associated with that situation.
