5303 rockshaft will not raise
/ 5303 rockshaft will not raise #1
Oletrapper
Kentucky
John Deere 2040, John Deere 5410, John Deere 825i Gator, John Deere 265 mower, John Deere 14T baler, John Deere #9 mower
I'm not new to TractorByNet but haven't been here for awhile.
I have a 2006 JD 5303 and the rockshaft arms will not raise. I am thinking something is wrong with the rockshaft control valve. Has anyone had a similar problem? Thanks in advance for any help anyone might provide. OT
/ 5303 rockshaft will not raise #3
Had the same problem recently with my Mitsubishi 2050. Happened unexpectedly at the far corner of the property while working the rear blade hard. Had to ratchet strap the blade up to get back to the shop. Wasn't looking forward to the repair, expecting major mechanical issues, since the hydraulic oil and filter had been serviced recently.
Had to remove the rops and fenders to be able to remove the top of the case, to which the control valve is mounted. Inside showed no mechanical issues (400 hrs), but I removed and disassembled the cylinder that operates the lift, no issues. At that point I figured it had to be in the valve, but I wasn't inclined to remove and disassemble it. Flushed it well, and reassembled. Everything worked fine once the air bled out.
I figure a tiny bit of dirt got into a check valve in the valve body, keeping the cylinder from developing pressure.
Hope yours is just as easy. I did have the advantage of a good parts diagram and service manual.
6 Row Harrell Stalk Chopper (A62177)
6 Row Harrell...
2001 Freightliner MB55 Bus (A61568)
2001 Freightliner...
2016 Ford F-150 Ext. Cab Pickup Truck (A61568)
2016 Ford F-150...
2020 MACK GRANITE (A60736)
2020 MACK GRANITE...
2022 John Deere 5055E (A62177)
2022 John Deere...
New/Unused 2in Ratchet Strap (A61166)
New/Unused 2in...
