"drag link": alternatives, B21
/ "drag link": alternatives, B21 #1
joea99
Marbletown NY
Kubota B21, JD 240GT
Is there an alternative to replacing the entire drag link (p/n 32721-57713), which goes for over $200 USD?
One end has an annoying bit of play in the end.
The ends look pretty much like "tie rod ends" but are welded and not threaded. I can live with it till it breaks, at that price.
I may attempt to find something close and do a cut and weld.
/ "drag link": alternatives, B21 #2
Buy some DOM tubing and tie rod ends and make your own. It might be the taper on the ends are standard but you'll need to measure them.
That crossed my mind, but this one has a curve or bend in it. I'll look more closely tomorrow to see if that really matters. I have no means of bending DOM tubing.
2007 PETERBILT FLAT TOP SLEEPER  385 (A60736)
2007 PETERBILT...
2020 CATERPILLAR 304E2 CR EXCAVATOR (A62129)
2020 CATERPILLAR...
2006 FRAC TANK 500BBL WHEELED (A60736)
2006 FRAC TANK...
2013 ORTEQ ENERGY GN182 GOOSENECK HOSE TRAILER (A58214)
2013 ORTEQ ENERGY...
2020 Broyhill Load and Pack Articulated Solid Waste Handling Vehicle (A59228)
2020 Broyhill Load...
Vertical Steel Well Tank (A61570)
Vertical Steel...
