B2400, any good?
/ B2400, any good? #1
njc110381
Member
Gloucestershire, UK
Kubota B4200
Hi guys. I'm looking to buy a Kubota B2400HST for general mowing work, front end loader stuff and some light log hauling in the woods. I'd probably like to also run a small chipper and log splitter, as well as a saw bench.
Have we got many owners of this tractor here? I'd really appreciate your feedback please. I want to make sure I get the right machine. I used to have a B4200 but it was too small really. Good for light mowing but not long grass, also not so good for running the saw bench. At 12hp I guess that's no surprise?! I was always impressed at how well it could pull a trailer though. I'm thinking at double the weight and power, the 2400 should be a good step up?
/ B2400, any good? #2
The B2400 should be great for what you describe. If you can find one in good shape and reasonable price. I have some B2150s (also 24hp but 4 cyl instead of 3.) I'd go with the 60" MMM unless you have tight space circumstances. May want to think about whether all the attachments of interest to you can be run off the PTO or do you need an hydraulic remote to manipulate some of them? There are several Kubota models in the 24hp range weighing 1500 to 2000 lbs , 800 to 900 Kg. I'd think most any of those models would be good for you so "good condition and reasonable price" are the deciding factors.
/ B2400, any good? #3
I have a B1700D (gear drive)...it is an awesome machine...about the only difference I can tell between a 2400 and a 1700 is the amount of fuel they use...
FWIW...The B1700, B2100, and the B2400 are all covered in one operator and maintenance manual...
The one single thing that these three tractors lack is overall weight...bare bones they barely weight 1500#'s...a loader will bump it up to just over a ton...I have the big (fat) industrial rears that hold about 30 gallons of ballast each so that really helps a lot...
These are not huge machines but they will do what you ask if you're willing to take your time...buy properly sized attachments for your machine..
Good Luck...
  • Good Post
Reactions: JWR
/ B2400, any good? #4
Plenty of capability for what you want. I've my eye on a B2300 for when to replace the JD 2025R. The 18.5 hp 4010 was plenty for me doing what you want to do.
/ B2400, any good? #5
My son owns a B2410 Bi-Speed with FEL and BB. Great little tractor. Very nimble and stronger than one would expect. Mowing with the belly mower is a workout though but it will get the job done. I think it would run a small chipper just fine but remember - it's only 24hp.
He sadly loaned it out to a 'friend' that promptly blew the motor up. Lesson Learned: Don't loan out your tractor!
He has since had the entire motor rebuilt as well as a total restoration other than new paint. That project took about a year and $5K. Meantime he added a B2650 to his stable and will be selling the B2410 sometime in the future although he's in no rush.
In his opinion, what's better than a B-series tractor? Two B-series tractors :)
/ B2400, any good? #6
That B2650 is an outstanding tractor from what I have seen. Do not own one, but if I were in the market that is where I'd go. I always viewed the Bi-speed (Bi-speed turn?) as extra unjustified complexity and trouble going somewhere to happen yet I've not heard a lot of complaints about them. They were only sold for a few years.
The B2410 is a 3cyl & does not have quite the oomph those older 4 cyl models seem to have. The chipper, properly sized, should work just fine.
/ B2400, any good?
Some reassuring info there, thanks guys.
I've been watching a few videos on Youtube and it looks like it'll probably cope with all I want to do with it. I may get a little Igland 2001 log winch to go on it, and a log grab for the front. There are a couple of guys doing similar stuff to what I plan to do with the smaller BX machines. They look useful but the ground clearance doesn't look so good.
Running the chipper may be a push, but I've seen a few 5" roller fed trailer models here in the UK that have 20hp Honda engines. I won't be doing anything big - much over 4" is good for firewood. I do wonder how it will get on with a hydraulic log splitter? I can do basic fabrication so I did wonder if making up a mount to fit a bigger pump to the belly mower pto could work?
The great thing about buying an older used machine is that if it doesn't work out I'll get most of my money back. If the older machine works out and pays well then it will earn the money for an upgrade. I prefer to pay with money I have in the bank, I don't like finance.
  • Good Post
Reactions: JWR
/ B2400, any good?
Also worthy of note is the flow rate of the hydraulics. B2150 - 28lpm, B2400 - 22lpm. That may be the difference between the expense and hassle of a PTO pump or being able to run a small hydraulic log splitter from the tractor system.
/ B2400, any good? #9
For the most part log splitters require pressure, not a heck of a lot of flow. That's why a little Briggs and Stratton runs a good sized log splitter.
/ B2400, any good?
That is true. But if I can decrease the cycle rate of the ram that's no bad thing. A lot of the small engined splitters use a two stage pump - they deliver high volume at low pressure until that pressure needs to increase to do the work, then they deliver low volume at high pressure. There's nothing worse than a slow cycle rate.
The volume needed between the wedge hitting the log and the log breaking is tiny. The flow needed to complete the stroke and return it ready for the next log is equally important unless you have all day to get not a lot done. The splitter I have here shouldn't take a lot, it's only a ten ton ram. What the bore and stroke is I couldn't tell you, not without looking it up.
/ B2400, any good?
I've just noticed the 2150 is about a foot longer than the 2400. It won't fit in my trailer! :cry:
Looking at slightly smaller machines, the B7500 seems nice. I probably should have titled this "help me choose a good little compact". Time for a new topic I think!
/ B2400, any good? #12
Won't fit in your trailer !? You're using an 8ft trailer I guess. The 2150 is just a tad over 9ft long. I was surprised that it is around 18" longer than the 2400.
The 2400 was the sucessor to the 2100 series in the 1990s when they came out with the 3 cyl engines.
/ B2400, any good?
Yeah 8x5. Driving around small Cotswold villages means anything much bigger is a nightmare. That said, it has wheel arches on the side rather than under it. I did consider a 10x6 flatbed could perhaps be a better bet. We've got roads around here where the mirrors of my Hilux need to be folded in for the truck to fit down them though. The joys of living in a place where the houses were built before cars existed!
/ B2400, any good? #14
Your first problem with the 5x8 trailer is that a belly mower won't fit in the width. I had to go to a 6.5ft wide for my 60" MMM on Kubotas. They are several inches wider than the 60" measurement.
/ B2400, any good?
Funny you should say that, I just had that thought today and looked up the specs. It won't go in, not even close. Maybe a 54" will, but I'm not sure about that either!
Having watched a few videos, worst case maybe I could disconnect the deck and put it in the bed of my pickup with the loader? That's assuming I could rest the loader bucket on the A frame of the trailer? I'm pretty sure that won't fit in an 8' trailer either!
2018 GENERAC MOBILE PRODUCTS MLT6S (A68842)
2018 GENERAC...
CAT 613B Transmission (A68134)
CAT 613B...
PACER 2" PUMP, BRIGGS & STRATTON ENGINE, HOSE (A64276)
PACER 2" PUMP...
2017 Nissan Altima 4 door (A63689)
2017 Nissan Altima...
2019 Ford F-450 Ext. Cab Knapheide Service Truck with Liftgate (A66736)
2019 Ford F-450...
2019 INTERNATIONAL MV607 REEFER TRUCK (A67714)
2019 INTERNATIONAL...
