Buying Advice Buying backhoe with the tractor upfront.
/ Buying backhoe with the tractor upfront. #21
Enjoy your BH’s gentlemen. I think they are not very useful on a little tractor that weighs less than 2000 lbs. We can agree to disagree
The used machines I have seen in that size range have BH’s that look like new. Once most people dig a trench or two and plant a few dozen trees they sit idle. That is a lot of $$$ doing nothing.
I have owned 20 acres for 9 years and had $600 of BH work done.
I have owned an intermediate TLB for 35 years!
A 1970 Ford 3400 for 33 years, and my current 2006 Kubota L48 for 2 years, both bought used.
I only put 500 hours on my Ford in 33 years.
I bought it for $10,000, sold it for $9,000, and did at least $75,000 worth of my own property maintenance, in addition to always having it available when needed, often for one hour or less.
I have been on my family 11.7 acres for much of my 80 years.
/ Buying backhoe with the tractor upfront. #22
One of the many things a backhoe is designed for is trenching.
But; add in, doing anything a shovel can do, lifting stuff, getting unstuck and so forth. It’s just like a mechanical arm.
Remember, tractors were originally designed to pull things. No pto’s, no buckets, just a simple draft machine!
/ Buying backhoe with the tractor upfront. #23
I used to have a tractor with a backhoe. I used it a lot. It was what I had and it was significantly better than a shovel. I do agree a backhoe on a tiny tractor is about worthless. Even the biggest tractor backhoes are weak. I have a mini excavator now and it’s WAY better than a tractor backhoe but that’s all it does is dig. It won’t mow grass, it won’t plow your driveway, it won’t carry mulch to your flower bed, it won’t till your garden. Well I guess it could do all of those things but not good. So unless you want to buy a tractor and mini excavator the tractor backhoe is a decent option.
/ Buying backhoe with the tractor upfront. #24
As others have often stated, a TLB is the Swiss army knife of small earth moving machinery.
/ Buying backhoe with the tractor upfront. #25
To the OP
Make a list of the jobs only a BH will do for your needs.
I have a local guy that charges $100/hr and he does twice the work I could do with a BH. Makes more sense for me to hire the work out.
There is no outright correct answer...it depends on your needs.
I earn 8% on investments. So instead of investing $6000 on a BH, I can get about 5 hr of BH work done a year free. With no wear on tear on my equipment. It works for me, but I have only had the guy here twice in 9 years. YMMV
Obviously, some folks here use their BH a lot and it works for them.
What do you need doing?
/ Buying backhoe with the tractor upfront. #26
To the OP
I have had a TLB for 35 years.
My current Kubota L48 TLB is worth 35% more (Tractor Data) than I paid for it used, 25 months ago.
That handily beats 8% per annum in my book!
And.......I have the machine available for use every day, if I should need it.
At 80, I use that wonderful mechanical arm with hydraulic thumb, more often than you might even begin to imagine.
/ Buying backhoe with the tractor upfront. #27
I’m not 80 but any time I can use hydraulics to do work it’s a good day. Here’s a gravel spreader I rigged up to push gravel in a 12’ porch.
/ Buying backhoe with the tractor upfront. #28
No. You rent a tracked mini-excavator complete, not a rental backhoe for the tractor. You can rent a much more efficient mini-excavator multiple times for the cost of a $5,000 backhoe.
shooterdon:
Easier and cheaper to get a local guy to do my BH work and pay him $100/hr for small jobs.
Yes. Perhaps $2,000 dollars more purchased after the tractor.
But you can’t use it at will if it isn’t already at your place.
Most of the jobs I get offered lately are those the owner thought they could rent something for, but rain, work and no rental available were problems that they encountered.
Owning and having ready at your disposal is also much more profitable when you add up all the costs, hassles and bull crap you put up with when renting.
Not to mention when you sell you get most of that back and then the rental actually becomes the more expensive option.
I have made way more than the cost of my last backhoe just doing small odd jobs with it for others over the years and I assure you there was much more completed than trenching!
/ Buying backhoe with the tractor upfront. #29
If you want to "wear out your back don't get a back hoe" yes you can do much more renting a mini excavator but for utility and having a swiss army tool at your disposal "when you need it" is key.
As others have stated a BH with a thumb is a tool you will never regret having it long term - like others mine rarely comes off as its not just digging - its picking up logs for cutting, picking/placing rocks, a brush grapple and more,
/ Buying backhoe with the tractor upfront. #30
I use my TLB for removing cactus, cedar trees, rocks, putting in water lines. It would cost me a small fortune
to have some one to come in and do all the work that I
have been doing and the best part is I have use of it when
ever I want to use it. No hassle to go to town to the rent it
shop fill out the paper work and drive home. And the time
it takes to go to town fill out the paper work and drive back
home I can have the job that I want to do done or about
finished because I don't need to spend the time to rent
and my BH75 does a fine job for me it sure beats a shovel!
willy!
Lots of good points posted. Still mulling it over. Adding backhoe to the same tractor is $4600 more. Seems like a reasonable add.
Only real trenching I would do is installing a water line to barn, but there are a couple of trees near the path I’m not sure this small tractor backhoe could get through the roots. 🤷🏻‍♂️
/ Buying backhoe with the tractor upfront. #33
My PITA backhoe has been used everyday that I have had my tractor. You think a backhoe is a PITA explain why so many small tractors are being sold with a FEL and BACKKHOE? and if the tractor does not have the backhoe they order one or order the tractor with a backhoe so all cables etc pertaining to the backhoe are factory installed?????? For the time to remove and install a backhoe takes approx 15 minutes each. My PITA backhoe can dig more holes in an hour than I can with a shovel all day! Also when I operate my PITA backhoe it gets to hot I can climb in the CAB and cool off, have a nice cool drink and then back working my PITA backhoe! I wonder how many small tractors with PITA backhoes jhave been sold here in the U.S.A this past year along???? And that's if a dealer can get a small tractor with a PITA backhoe on it because they can't keep them in stock!
willy
Dealers would paint flames on the sides of all their tractors if they could sell more that way. Why do people buy 4x4 quad cab pickup trucks with 4 foot beds when they run with one occupant and the bed empty 99% of the time?
I think the majority of SCUT TLB buyers are looking for garage ornaments to impress neighbours and friends. Or they buy them thinking they will be doing all this work around the house lifting 2,000# rocks with their 1,600# machines. In reality SCUT TLB's are like buying the Swiss Army Knife with the fork and spoon and tree saw and a thousand other attachments you never use or want to.
A few electrical contractors buy them to bury lines in tight spaces but usually they go for the mini-x's which tend to be more suitable for the work.
/ Buying backhoe with the tractor upfront. #34
old and tired brings up a good point about a sub-frame. I can't remember the source, but read recently about damage done to tractors from 3 point hitch mounted back hoes. If you bought a 3 point hitch backhoe, you would find one readily available used and not pay "new" price - and that way could assess your needs before buying the attachment. But if the tractor you're considering comes with a 4 point backhoe and sub-frame, you'll not find one used, and dealer will get customary markup - not be wheeling and dealing trying to make the sale of the tractor.
/ Buying backhoe with the tractor upfront. #35
To the OP
Well It looks like you have a cab tractor that I am guessing cost more than $30,000. You probably have a lot of implements and attachments as well. Plus upkeep costs and fuel and garage space wasted. You could have saved all that money and just hired someone to maintain your property for cheaper than that. So I dont think anyone is buying any of these scuts or cuts or tlbs to save money, lol. Because you are not unless you use it in a business. Also there is always a faster machine you could rent to do anything you are doing with your tractor. So anyone saying a bh attachment is an unnecessary thing because its "cheaper" or "faster" to rent a mini ex should also be saying it's better to not buy the tractor in the first place because it's better to rent one, lol.
My point being that the majority of people are buying these scuts or cuts or tlbs because they are handy tools we buy to own and have available when we want them because we enjoy using them. Not because it is a money saver or time saver. So my advice is get what you want, what you can afford and go have fun and enjoy the accomplishment of doing your own projects and/or maintainence with your property.
/ Buying backhoe with the tractor upfront. #36
1000% FACT !!!!
/ Buying backhoe with the tractor upfront. #37
Garage ornaments?
I honestly don’t know anyone who buys attachments they don’t use. Most take the time to investigate and learn what things they need to do the tasks they want accomplished.
There are a few who get misled and end up with something they decide wasn’t the best for the job, like a grader blade compared to a box blade for reoccurring driveway maintenance but we are not talking about such a limited use tool.
One of my nieghbors just dug his own trench for his solar panel install. He saved over 2000.00 by doing that with his as those here say undersized, underweight tractor with a as some here say undersized weak not capeable backhoe. Took him a little over 5 hours. My math on his exact numbers figures he earned 480.00 an hour that day and if his backhoe was priced the same as the OP’s then he now only needs to figure out how to make it save him 2200 more.
Sometimes I think that people can’t do simple math.
Now if he never does anything else with it again and sells it a few years from now how much do we estimate he lost?
Again simple math.
Let’s say he plants a few trees, has a tree come down in the yard and used the thumb to reach in and get a hold of a branch he can’t get to with the loader to get the wieght off when he pinches his chainsaw and gets it stuck. Pops a new hole in the ground for the mailbox his nieghbors goofy kid knocked down. Ripped out that old overgrown hedge line his wife hated. Dug a few French drains for water control. And then used it to help dig out new walkways to improve his landscaping at his own liesure and then dug some holes to plant a bit bigger trees or bushes along that landscape which makes his other half very happy and adds significantly more value to his home.
Add that math to the cost at time of sale.
Even this simple but actual description of one of my nieghbors current use covers the OP’s upgrade cost by a large margin.
Now look at his rental costs for the same.
Trenching 2400 paid to the installing company
Or running around looking for an availiable rental unit ( time/ fuel/ wear and tear) let’s just say comparable guess around here due to my knowledge of our local rental shop 200. Then actually having to drive out of the area to get satisfaction and it’s costs including most likely having to leave work an hour or two early to accomplish it about an other 120 to 150 bucks and remember he doesn’t even have the dam thing here yet.
Then comes the rental fee Let’s see that’s 500 with a surcharge for the out of area delivery because he can’t pick it up himself 75.
Now he was only able to get it on a weekday because all weekends for the next 6 months are already taken by other customers. So he will loose an other day of work. Add earnings let’s say 400 to try to get a balance between different type of people.
Let’s hope the weather on his rental day was good, but it wasn’t so he got sick from being out in the rain trying to get his moneys worth and got the job done but now he is out sick for two days from it. More work lost 800.
Next comes that hedge line my nephew does it for him as an under the table job actual price my great-nephew gave someone( a 14 year old boy for a real hedge along a nearby property) 350.00
How about planting those trees. Remember he doesn’t own a trailer and he got the Idea to plant them by seeing me bringing home some real nice but rather large trees that I got a holesale deal going on with. He asked and I offered to take him with me and get him some my next trip out that way which means his time is limited and he will need the holes dug and has no time to play the rental game. So it’s pay someone or don’t get them if you think your getting 5 holes dug for trees that big done on a hundred dollar bill in less tha 3 days your a bigger fool than I can imagine. So add 500.
Now look at the chainsaw stuck in the downed tree. Yep it really happend to him and I will give the price my landscaper/ tree trimmer friend gave him to get it out but included him finishing the job because at that time he was disgusted and about to give up till I told him that the backhoe with the thumb would easily be able to reduce pressure.
So the cost of that would have been one wasted chainsaw 150 ( guessing) + 475 to come cut up the rest of the tree.
French drains are next on his list. Let’s just go with the rental cost for one day again and skip the crap with our shoddy local rental place which is 575 for rental and delivery plus his time out of work again.
Next is the walkway again by now he is getting some experiance and waits till it’s availiable on a weekend. so It’s only the rental and delivery at 575.
If I stop there I think we are at about 5500.
Is that not more than the cost the OP stated.
By the way this is based on one of my nieghbors actuall experiance except that it was his goofy kid that knocked down my mailbox and he had to fix it for me and the hedge line was estimated based on the other nieghbors hedge because I don’t know what his would have cost on his hedge to use.
Anyway seems to me a backhoe might not be a bad investment for the long haul. I wonder if the value added to my place just with the patio dug out at the hillside alone wasn’t an equity improving upgrade large enough to cover the hole cost of my last tractor not just the backhoe.
/ Buying backhoe with the tractor upfront. #38
It all really boils down to the potential use of the tractor and can you afford to buy the implement. $5k isnt a small sum to finance and use once in a while. Dig a hole for a mailbox? With a backhoe? Guess you are really kidding us. I just did this and used a shovel. Too many rock for a post hole digger and as my box is a firearm ross the road in a curve there would be zero way to use a backhoe even if it was the right tool. 30 minutes with a shovel and it was in the ground.... even with rocks. So free. How many shrubs do you have around your house that your wife would allow you to pull up?
Are you trenching often? are you using for profit? i.e. are you renting out you and your tractor? if so, it may make sense.
BTW, lifting things would be one of my major uses. I get by with the endloader, but in a lot of cases the bh would work better for higher things.
I've just had to have a powerline and waterline trenched for my daughter's new house. Might have been a bit cheaper if I'd had a bh, but with depth, it would have taken a 50hp or larger tractor. And the guy dug it in about 2 hours.....
Get it if you can afford to leave sitting most of the time.
/ Buying backhoe with the tractor upfront. #39
Garage ornaments?
Again simple math.
"There a few who get misled"..... and buy a grader blade instead of a box blade for driveway maintenance?
You got that part of your usage assessment completely backward!
A box blade is for moving material!
A grader blade is for shaping material......as in driveway maintenance.
/ Buying backhoe with the tractor upfront. #40
Apparently you never used a small bucket on a backhoe to dig out For a mailbox. A half hour? Took him about 2 min. Not kidding!
2018 Regal 29OBX 29ft Boat with 34ft T/A Boat Trailer (A59231)
2018 Regal 29OBX...
Bobcat mid mount mower M60-5 60" CT2025
Bobcat mid mount...
2015 Vermeer MX125 500 Gallon Drilling Fluid System T/A Trailer (A59228)
2015 Vermeer MX125...
2007 Chevrolet Suburban Multipurpose Vehicle (MPV), VIN # 3GNFC16097G214917 (A61165)
2007 Chevrolet...
2012 KINZE FLAT FOLD ROW MARKERS SET FOR 12 ROW 36/38 STACK FOLD TOOL BAR (A55315)
2012 KINZE FLAT...
1996 Sunflower 1543-38 Folding Disk (A61307)
1996 Sunflower...
