VoIP issue
/ VoIP issue #1
OzKioti
SE Queensland, Australia
Kioti RX8030 & loader
I've been using VoIP for some years now, but have always had an issue where I can't be heard until the other party stops talking/takes a breath. On the old landline, you could chime in with a comment at any time, and be heard. With my VoIP, I can try to interrupt as much as I like but the other party is completely oblivious to my attempt to interrupt.
I've got used to it, but it's like the old two-way radio protocol, minus the "Over" and "Out" ;)
I'm about to change VoIP service providers, so will see if that changes anything, otherwise there is probably a setting I need to tweak in my ATA - A cisco SPA-122.
Has anyone else experienced this irritating aspect of using VoIP?
/ VoIP issue #5
I had Vonage VoIP for a while and had none of those issues. Who is your VoIP provider?
Likewise, and I never had any issues either. In fact, anyone who has a cellphone or phone service part of a cable bundle is using VoIP anyway.
I think the OP needs to contact his provider and see what they can do.
/ VoIP issue #6
Never had that issue with VOIP. I suspect it is your provider, or software settings.
All the best,
Peter
/ VoIP issue #7
We've VoiP with Xfinity/Comcast. No problems. I have to wait until the other person finishes because I read the captions translatiing what they said on the screen. Have to wait for the captions. I tell them this, in case they're wondering why I don't respond right away.
/ VoIP issue
OK, thanks everyone for your responses. What it tells me is that what I'm experiencing is not a characteristic of VoIP.
Some time later:
Many many moons ago we got a Panasonic 900MHz cordless system to replace an old wall-mounted phone. The old phone was produced in the 70's - not old enough to have a rotary dial, it had the fancy new style DTMF push button dialling. Anyway, after much searching this morning, I found it, dusted it off & plugged it into the ATA (analogue telephone adapter) and it works like a charm. Just like in the old days using copper wire from the nearest exchange!
So the problem is the cordless phone. I phoned my neighbour, and no problems at all with the old phone, but when we tried again using the cordless phone, he can hear me interrupting, but when he tried to interrupt me, all I heard was very short fragments of what he was trying to say.
So thanks again everyone.
Cheers
/ VoIP issue #9
You can't quite bundle all VOIP Devices together because they are night and day different. Voice takes a lot of bandwidth and has to be given packet priority since voice won't retransmit but data packets will. Anyway, lots of differences in them.
/ VoIP issue #10
A lot of band width is relative, especially with the newer codecs. They typically attempt to do some sort of QOS so latency issues and fragmentation don't make the sound crappy. Funny, humans are really sensitive to network issues where audio is concerned, but video we can let things slide quite a bit.
Where i work, the courts very rarely call about video, but audio issues, is pretty routine.
/ VoIP issue #11
Well, you better do some kind of QOS or the voice is gonna be crap. There are 3 kinds of voice codecs and they all have been around for years, not aware of any new one's. You can pretty much choose one for best bandwidth usage or best quality which uses the most bandwidth, so yep, it's all relative to how deep your pockets are.
/ VoIP issue #12
Your right, i was thinking video codec. Most of the sound issues we see are maladjustment of audio gain/volume.
/ VoIP issue #13
I had a similar issue and it turned out my voip provider needed a specific port range open in the router settings. Once I forwarded those ports and disabled SIP ALG on my router, the call quality got way better. You might also want to check if your voip provider has a list of recommended router settings—that made a big difference for me.
2021 Chevrolet Traverse SUV (A64557)
2021 Chevrolet...
2000 INTERNATIONAL 4900 - 10 WHEELER GRAIN TRUCK (A64278)
2000 INTERNATIONAL...
JCB 3TS-8T SKID STEER (A65053)
JCB 3TS-8T SKID...
2016 CATERPILLAR D6K2 LGP CRAWLER DOZER (A65053)
2016 CATERPILLAR...
2017 Ford Fusion Hybrid Sedan (A64557)
2017 Ford Fusion...
2005 Chevy Suburban (A66408)
2005 Chevy...
