/ How the heck do you guys torque a cylinder nut to 600 ft lb? Rebuilding Bobcat combo bucket cylinder.
#1
Torque multipliers use a fixed gear ratio. It's not going to get "out of calibration" or be "inaccurate ". Output will always be the same multiple of the input.Look up "torque multiplier". The question is the accuracy of these things. You can spend a lot or a "little".
What does "bottom nut" actually look like.... May determine on approach to achieving 600 ft-lbs....I am putting new seals in and apparently I need to get the bottom nut to 600 ft lb. I do not have that kind of torque wrench. How do most people achieve this? Thanks.
Or some other math solution. I'd use a 2.5 foot bar and my 240 lbs.150 lbs on a 4' bar. Really not that difficult if you have a 3/4 drive socket set.
NO!!! We could also avoid a discussion about the anality of absolute torque values.Do we want to open the discussion on lubricated vs non lubricated surfaces and threads?![]()
