Differential lock was stuck
/ Differential lock was stuck #1
VroomVroom
Newfoundland
Mahindra 2816 HST, Super M farmall, J5 bombardier, 230 timber jack skidder
I haven't used the tractor much lately, only to move around a trailer and some odds and ends amounting to no time. However, the other day, I was palleting some stuff on the three point, and moving the trailer around again, and I did notice the tractor was biting more while turning. later on, I realized the differential lock was pressed down. Normally this comes out of position when your heel is removed from the pedal...so I'm not entirely sure how long it was on for. I'm going to say since I last snowblower with the tractor to now I have less then an hour of actual tractor moving . All in low gear. though I was putting some decent weight on the rear forks the day I found that, and turning around. Not happy about it. I hauled the pedal up by hand. I don't see a spring of any sort to pull it up. And it was stuff and I worked it up and down 30-40 times, while sticking a straw and wd40 spraying in arm coming out of tractor. But I really don't see anywhere to lube this. The pedal probably had 5 or 6 inches of up and down movement, with only the last 2 inches of movement of actual differential lock engagement. Anyone have this issue?
/ Differential lock was stuck #2
I had the same problem on my 2615HST. Where the linkage goes into the trans it was sticking. I guess it had rust buildup due to being left outside in the rain. No way to lube. I used a spray penetrating oil and manually worked the pedal up and down. At first I had to pry the pedal up and step on it hard to push back down. It took about 2-3 hours before I could easily move the pedal by hand. My dealer offered no solution so I just spray it on every use. I also added a spring to assist pulling the pedal up.
I'd suggest using a penetrating oil with capillary action. IMO WD40 is too light duty.
ok, thanks. Yeah, I only had the wd40 with the straw on hand. I do have a can of liquid wrench that sets up like a white grease. Maybe I'll sprat some of that in there. I have to look down through a hole in the fender to even see where it enters the side of the tractor.
/ Differential lock was stuck #4
Yep....keep spraying a penetrating fluid and try to get the shaft to move. This is a common issue regardless of tractor make.
/ Differential lock was stuck #5
If your dif lock does not disengage during operation, which is not that uncommon, you can usually release it by stepping on your steering brakes. First one side then the other. It releases pressure on the locking pin in the differential so that it can retract.
gg
/ Differential lock was stuck #6
My diff lock has been stuck engaged on my B2620 for a long time now. It's actually kinda handy for all the uphill box blading I do on my bush road. LOL
Doesn't really tear the lawn up mowing and not causing any tire wear so I'm not really concerned. If it ever fails then I will fix it.
/ Differential lock was stuck #7
IIRC, one should release the diff lock ASAP while driving straight forward and not in a turn. Seems like some threads have spoken of some damage to the transmission otherwise.
Cheers,
Mike
Yes oldballs, I used mine I’m guessing less than an hour and was concerned I did that. I was on dirt road and baseball size blast rock turning around a little during. Half of that time was lifting heavy stuff with three point to. I felt bad afterwards I realized I did it that much
/ Differential lock was stuck #9
I had the same problem, occasionally, on my Ford 1700. Never thought of the steering brake solution. I would stop - go in reverse for a few feet - the diffy lock would always release.
/ Differential lock was stuck #11
Some older B models like B7100HST in the manual stated should only go forward or backwards avoid sharp turns.
/ Differential lock was stuck #13
Oh well, it is what it is. When it breaks I'll fix it.
You’d probably be better off to part it out and scrap the rest for the cost of fixing a transmission case full of metal
/ Differential lock was stuck #14
Wait until you see how much THAT cost, you will wish you had "fixed it before it broke"!!
SR
Agree 100%
Occasional drop of oil where the diff lock pedal exits the differential housing will keep it working smoothly - it is called preventive maintenance.
I know many people are not big on that, they just fix it after it's broken!
I keep an old style lube oil can filled with filled mixture of 30W or 10W-30 oil and some STP engine oil additive.
Works way better than WD40 etc. spay in the long run.
/ Differential lock was stuck #15
Long shot OP, but check the fluid level in that axle.
I don't know your tractor/axle layout, but if there is some reliance for lube internally (splash/slosh), then I'd want to check esp. if you are all flatland.
If you work on billy-goat trails like some do, the axle could be half-empty and still slosh plenty though :cool:....
Rgds, D.
/ Differential lock was stuck #16
Fluids are fine. Change them and filters long before what is called for. Pedal moves freely. Just notice sometimes both wheels spin.
Oh well, it's a 2013 so time for some new toys anyway.
The 55 Allis will take over while I wait for the new Kubota to come in.
2017 CATERPILLAR 289D SKID STEER (A65053)
2017 CATERPILLAR...
2012 FREIGHTLINER M2 6X4 T/A DAY CAB TRUCK (A66091)
2012 FREIGHTLINER...
2021 CATERPILLAR 289D3 SKID STEER (A65053)
2021 CATERPILLAR...
2019 KUBOTA KX71-3 SUPER SERIES EXCAVATOR (A65053)
2019 KUBOTA KX71-3...
2013 FREIGHTLINER CASCADIA T/A 6X4 DAY CAB TRUCK (A67147)
2013 FREIGHTLINER...
2011 Kenworth T800 Truck T/A Wet Kit Sleeper Cab Truck Tractor (A64194)
2011 Kenworth T800...
