422 and 425 attachments
/ 422 and 425 attachments #1
Goose1776
Gold Member
Massey 2706e
Does anyone know if the 422 and 425 use the same mowers? Or post hole diggers?
Terry had told me the plates were the same, but I forgot to ask about any hydraulic implements.
I was assuming a 425 could use any 422 attachments, since the plates are the same.
/ 422 and 425 attachments #2
I just did quick pass through both price lists, and I'd say no. Odds are the PT-422 stuff would work on the PT-425 but not the other way around because the PT-422 doesn't have the hydraulic grunt for the larger PT-425 implements. The PT-425 will probably be amused by the smaller PT-422 implements and you may have to rig up some gender benders and adaptors, but hydraulically it should go.
Looking at the specs for both, they both have 8gpm at the PTO, so I’m guessing, they will work.
If my dice roll right, I’ll let everyone know for sure. LoL
/ 422 and 425 attachments #4
Does the 422 and 425 PTO operate at the same relief pressure?
/ 422 and 425 attachments #5
I just did a pass through the price lists for both the 422 and 425 and they have the same part numbers, so, yes, they are the same.
However, you'll notice they don't recommend the 60" mower for the 422. It's not on the price list. 20 years ago I spoke to Terry at PowerTrac and he said you'll want and need the extra HP to spin the larger deck.
But both the 422 and 425 use the same 48" finish mower, brush cutter, post hole diggers, trenchers (but a few accessories aren't offered on the 422), brushes, snow blower, tillers, etc...
Here's the 422 price list
And here's the 425 price list
Compare the parts numbers. They are the same.
/ 422 and 425 attachments #6
I'd call Terry at PT and tell him the tasks you want to do and see what he recommends as to if the 422 will do them well.
If I can do the financial gymnastics, and clear some other hurdles, I’m going to try to add an extra 425 to my garage.
But it is a long shot.
/ 422 and 425 attachments #8
The old 422 and the 425 were the same machine except for the engine...... jim
/ 422 and 425 attachments #10
That's odd - pulled them both and they were NOT the same. Huh. Must be something cashed on this PC or something. My apologies.
/ 422 and 425 attachments #12
The newer one got the single steering cylinder ..... jim
The new 425 only has one steering cylinder??
I thought it had 2. 1 on each side?
/ 422 and 425 attachments #14
The 422 now has one steering cylinder instead of two on the older ones, 425 has two..... jim
Here is my used attachments find.
Boom pole
Trailer mover plate
Pivoting post hole digger with an auger
Mini hoe
Box blade
Finish mower.
Got it all for $2600. Which I thought was worth a 12 hour round trip drive to retrieve them.
Now to head back to Tazewell to pick up a 425 with bucket, grapple and rake.
/ 422 and 425 attachments #17
Boom pole
Trailer mover plate
Mini hoe
Box blade
Finish mower.
What a great find
2023  FREIGHTLINER M2 22FT NON CDL BOX TRUCK (A59905)
2023 FREIGHTLINER...
Year: 2018 Make: Towmaster Model: TC-16 Vehicle Type: Trailer Mileage: Plate: Body Type: Trim Lev... (A61567)
Year: 2018 Make...
2022 EZ-GO ELITE...
2021 UTILITY VS2DX 53FT DRY VAN (A59905)
2021 UTILITY VS2DX...
UNUSED WOLVERINE 6' SLIP ON FORK EXTENSIONS (A64281)
UNUSED WOLVERINE...
KUBOTA MI08S TRACTOR (A63276)
KUBOTA MI08S...
