Good morning!!!!
   / Good morning!!!! #135,641
PopG - how much does that beam weigh?
The original beam is a hand hewn Chestnut beam with mortised posts. I’m not sure what it weighs, we added steel flitch plates to either side and drilled through the beam (about 12”) to bolt the plates together, sandwiching the beam. Each piece of steel weighed about 140 lbs. I had square holes for the carriage bolts water jet cut into the plates with close tolerance fit, so the challenge was to drill the holes dead square and level so the bolts would go through the holes.
   / Good morning!!!! #135,642
Less humid tonight.
Finally changed the HST filter on the L3940. One of those jobs I started a year ago, but couldn’t get the filter off with plyers. Turns out to be very easy, hit the grooved base a couple times with a punch and hammer and it turned easy, then used filter plyers. Used the vacuum on the fill hole, and loss very little fluid, most from the filter.
Lillies really smell good.
Battery on husqvarna mower wouldn’t charge. Did sharpen the blades and cleaned under the deck, and mowed a lap. Going to take it to dad.
   / Good morning!!!! #135,643
Good evening all. 70F for the start,clear,light breeze. Light wind moderate gusts, some cloud build up in afternoon, and high temp 92F, HO 98F, and DP 66F. Took wife to dermatologist appointment this morning, grocery shopped while she was getting skin growth removed. then came on home. Bike ride was very sweaty, then lunch, nap and play with new MP3 player.
Covid update: Cooke 3241 confirmed cases, 5 active cases, Montague 1801 confirmed cases, 10 active cases, Grayson, 11374 confirmed cases, 13 active cases.
RS nice score on the router, sorry about the outside shower.
Don sorry about your niece and son prayers for their recovery
Drew sorry about the lack of guidance, and the rude wake up you got
Doug nice truck
Ron enjoy your unstructured day, nice pic of guard duty
Drew enjoy new mower :)
Buppies good luck with the humidity
Dennis nice amount of rain
Billy sorry about the grease gun woes. hope you can power through the humidity
Paul a new piece of equipment to borrow? Quite the beam project.
RNG hope the fires don't get you. glad bike maintenance is comping along along with the fittings to hook up your water pipe.
Don thanks for niece update, sorry about the rank slippage in H&F tourney
Randy hope you can beat some od the heat.
James thanks for the info
PJ I remember well, relied on cable channels for anything but baseball.
Ken sorry about the lack of weather cooperation. yes crane would be nice till time to fill the fuel tank :) maybe bit more fog to start the story
David glad mowing going better
RS nice pic. hope you can get curl cylinder fixed soon
Drew good job to get them planted
Doug nice pic, and bed cover
Thomas glad you got an inside day
prayer for all, especially Jay/Peg, Kyle's daughter, Bird/aging issues/daughter's foot, Billy/skin cancer surgery, David(moss)/remodel/divorce, Buppies cancer surgery, Phil/reflux/wife's eyes,Steppenwolfe/son-auto immune disorder, Dennis/older brother/son, Grev/wife's eye, Randy/vision issues, Bill/DIL home care, Ted/knee recovery, Doug and wife/health issues/nerve and pain/ wife's eyes, Ken/uncle, Drew/tendon healing, David(sadamo)/Sophie's eye surgery,RNG/fire season, and Country.
stay safe and healthy you all.
   / Good morning!!!! #135,644
Another 4+ hours mowing, good progress. Unfortunately that set of Kevlar belts didn’t last. All three like delaminated in less than 10 hours.
Sent email to vendor.
   / Good morning!!!! #135,645
good morning all
a warm 71 going up to 91 today in fair weather.
David, sorry about the belts. Something must be out of alignment? Those kevlar belts should be durable...
nice lilies Buckeye. Can almost smell them from here.
   / Good morning!!!! #135,646
First cup of coffee is cooling. 65° with cloudy skies this morning. Heading to 83° with sunshine in afternoon. Took all day to get .27" of rain yesterday. Did a little touch up paint on table and chairs. I think that project is done except for moving it into house. Take Sassy for grooming this morning. Then put weed killer down. May need to mow grass when it finally dries out.
Alien, cover looks good.
David, something going to use up another set of belts. Something else wrong with bearing where you replaced bolts?
Buckeye, nice looking lilies. Have not figured out what has happened to my lillie garden. Its either deer or a red bug that has killed almost all of them.
Everyone stay safe and healthy.
Good Morning All.
   / Good morning!!!! #135,647
A bit more on my belt problem.
Seems I couldn’t keep the kevlar belts properly tensioned. I could mow maybe an hour before they’d be slipping too much. Eventually to the point that I ran out of adjustment.
I replaced them with a mismatched set of non kevlar, previously used belts and mowed another 2 1/2 hours without problem and when done the the tension seemed just as I started.
   / Good morning!!!! #135,649
Another hot and humid day if you walk 10 feet soaking wet
Nice truck Alien
Sorry about belts Sodamo
One company we do work for that has over 150 trucks has brand new one with bad ecm dealer cannot get part till 2022. Is our supply chain broken?
Prayers for all
   / Good morning!!!! #135,650
Good morning! 69˚F heading to mid 90s. Yesterday I got half the tin on the side of the barn before I saw a storm heading in my direction. The sky was turning black. I took off for the drive home and the winds were really strong shaking the Ranger and traffic slowed to 35mph in the torrential rain. Mom said at her house there was no rain but the wind was really strong and she could barley close the side door to the garage. I am suspecting there is more wind damage and missing tin to the barn as I was not able to seal it up. Oh no. No rain at home.
A lot of "BreakThrough" Covid cases being reported. 333 in Austin. Don't know if the reported 5% of vaccinated will still get covid or if it is a higher % outside of the study. Is your area in reporting breakthrough cases?
2019 GENIE S-45XC TELESCOPIC BOOM LIFT (A52709)
2019 GENIE S-45XC...
2015 Chevrolet Silverado 2500 4x4 Crew Cab Pickup Truck (A56858)
2015 Chevrolet...
Mini Skid-Steer Hydraulic Root Rake Grapple (New/Unused) (A59225)
Mini Skid-Steer...
2015 Ford F-350 Cab and Chassis Truck (A56858)
2015 Ford F-350...
New/Unused CFG Industrial MX12RX Mini Excavator (A57453)
New/Unused CFG...
2018 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A55973)
2018 Freightliner...
