John Deere 2520 died, won't start
/ John Deere 2520 died, won't start #1
tmshort
Indiana
2011 JD 2520
I was out tilling today, going along no problems and the tractor just died.
When I turn the key on, nothing on the dash comes on. No glow plug light. No fuel pump noise.
Fuses are all fine.
Battery is good - just replaced last fall, all the connections are clean and tight.
Lights still work.
When I pull the connectors at the solenoid and fuel pump, I detect no voltage.
I pulled the connectors for the safety stuff, bypassed them with no change.
I am at a loss. What is the next step in troubleshooting?
Thanks in advance for the help.
/ John Deere 2520 died, won't start #2
Take your volt meter and measure between the negative battery terminal (not the cable end) and a good ground on the tractor. If you have voltage, your ground connection from battery to frame is fubar. Needs to be cleaned up and retightened.
Thanks.
I have checked the battery connections and ground, all is good there.
/ John Deere 2520 died, won't start #4
tmshort
Did you clean/tighten battery cable where it attaches to tractor frame? Have you load tested battery? I've seen battery cables corrode inside insulation a considerable distance therefore loosing good connection. Have you attempted to start engine utilizing another vehicle & jumper cables?
/ John Deere 2520 died, won't start #5
Saying you just replace the battery last fall does not make it good, just relatively new. Check the voltage with the key turned off and again with the key turned on. Readings should be the same, somewhere around 12.6 volts. If it's much lower than that you could have a dud or the charging system could be at fault.
Closing the loop, as I hate finding these threads and no solution.
Long story short: it was a $%^@#*$&^ing fuse!
Initially I pulled all the fuses and they looked OK.
I pulled all kinds of stuff apart, undid wiring harnesses, etc. Found some rodent damage which I fixed (park brake indicator, but I knew this already).
Reluctantly, I bought the downloadable shop manual ... it was cheaper than a load and trip to the dealer, and I needed the tractor back online sooner.
The manual is great for troubleshooting. After I went through the steps, it didn't make sense - so I checked fuse F3 again and tested with a meter ... it was blown. Replaced it and all is good. Initially I was worried there was a short somewhere that caused it, but I ran the tractor for 2h yesterday (tilling, hauling with FEL, running the chipper, etc) and had no further issues.
Fuse F3 is the one labeled "timer" on the box. It is a small blade fuse.
So there you have it. Next time, I will be more meticulous about checking fuses!!
/ John Deere 2520 died, won't start #7
Thank you for "closing the loop". I was waiting with more than casual interest since my 2008 2520 will probably do this to me someday and I need to be prepared. You are correct in that the shop manual for this model is very good.
Frank
/ John Deere 2520 died, won't start #8
I am having this exact same problem. Key on, no gauges, no crank, no lights or flashers. Brand new battery, switch tests fine, fuses all good. Power to the fuse block. Wondering if it isn't a ground problem?
/ John Deere 2520 died, won't start #9
Over many yrs being associated with operating/repairing farm tractors & equipment I've frequently witnessed poor battery ground cable to frame electrical continuity due to poor connection or corroded ground cable inside of insulation.
KISS=keep it simple SENOR'
/ John Deere 2520 died, won't start #10
I had a similar problem on my jd2210. Seemlngly starter not strong enough. I think I caused the problem by using FE loader to lift some heavy stuff out of balance. It put the tractor into a twist. Due to that twist the gnd connection thru the frame was less effective. In the end I installed another gnd cable in parallel that ran directly to the starter frame. Now it spins right up. It sounds simple but it took me few days to figure it out.
/ John Deere 2520 died, won't start #11
OK, happily closing the loop (again) on a dead 2011 JD 2520 Compact electrical problem. The culprit turned out to be rust under the bolt holding the negative ground cable to the frame. The cable end looked 100% clean, shiny, and normal where it bolted to the frame but it was rusted under the attachment bolt head. I sanded off the cable end and the underside of the bolt head and just like that it's fixed. Seems obvious once I found it but remember, I had voltage at the switch, the fuse box, and the starter so there was no reason to think anything was wrong with the battery cables. There was also no visible corrosion anywhere. So it looks like nominal voltage could pass thru the rusty connection and be read on a multi-meter at the start switch, starter, and fuse box but once a load was applied, the rusty connection was unable provide any amps at all. I read up on this a bit and the electrical guys call it constriction resistance. Anyway, the tractor is back to work and I'm happy. Posting this info in hopes of helping the next guy. Thanks to everyone for the input.
/ John Deere 2520 died, won't start #12
Glad you got it going!
Battery cable connections (all 4) are the first check. 2nd is battery—have it load tested.
/ John Deere 2520 died, won't start #13
Yes, its called ohms law. V=I x R, so if you have some resistance if the load current, I, is very small then the voltage drop across that poor connection, R, is very low. So under a low load your multimeter will show full voltage. As soon as you turn on something, light bulb, starter etc, the voltage drop across R is very high and voltage measured on other end is very low.
Its kinda like connecting a small pipe to a huge pipe. As long is water is not flowing the pressure at the end of the small pipe is high, but once water starts flowing pressure will drop at end of small pipe.
As I mentioned in order to make my starter run at max speed I ran a separate heavy cable from - of battery over to the starter bolt that attaches starter to motor.
/ John Deere 2520 died, won't start #14
Wonder how many people test their cables with a volt/ohm
meter because if they get corroded could eat the center of
the cable and then you have two pieces of cable instead of
one! As fuses go I always test with meter looks can be
deceiving!
anyone hear anything about the 10 days no power or internet???
willy
/ John Deere 2520 died, won't start #15
deceiving!
willy
You can find gross problems with a volt/ohm meter like totally open circuit, but lets assume you have just a poor connection of .05 ohms which most meters can't measure. Assume 200A starting current and you get .05x200=10 volts drop in that connection and your starter will only click if you are lucky since it only gets 2 volts.
Marine stuff is even worse, unless you have very good cables the salt water travels down the wire under the insulation until it corrodes the wires.
/ John Deere 2520 died, won't start #16
This a great reason to get a meter that reads dc amps. If the amps are not present through the cable, but are present at the battery, you have found it answer. Unfortunately this is not a common feature on meters.
/ John Deere 2520 died, won't start #17
AT AMAZON​
UNI-T UT204R Digital Clamp Meter, Auto Ranging TRMS 6000 Counts NCV Volt Amp Meter with AC/DC Ohm Diode Capacitance Resistance Temperature Frequency Continuity Test $61.28
willy
