4630 pto problems
   / 4630 pto problems #1
Chasmac
Pto will not engage but pto brake is working ,linkage is good adj correctly,oil is new and right oil new filter, what's next before I have to split it?
   / 4630 pto problems #2
Since no one else has replied, how do you know the PTO brake works? Do you have the repair manuals for the tractor?
   / 4630 pto problems #3
It's an independent pto so there must be a clutch pack that that engages the input shaft. The brake just stops it from spinning when you shut it off. The brake is hydraulically actuated when you shut off the pro IIRC.
   / 4630 pto problems #4
Do you have the repair manual for the 4630?
2014 GMC Sierra Crew Cab Pickup Truck (A50323)
2014 GMC Sierra...
ASSET DESCRIPTIONS & CONDITION (A51219)
ASSET DESCRIPTIONS...
Cat TH407C Telehandler (A52128)
Cat TH407C...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A50323)
2013 Ford F-150...
2012 KENWORTH T400 TANDEM AXLE 24FT REEFER BOX (A51222)
2012 KENWORTH T400...
2021 Isuzu NRR Heil 9Yd Mini Rear Loader Garbage Truck (A50323)
2021 Isuzu NRR...
