Intermittent dead ignition
/ Intermittent dead ignition #1
schneidvt
Member
Summerfield, NC
Ford 1500, Kubota 4240, Ingersoll 2014
my father has a la series kubota around 2009. He told me it wouldn’t start on a couple occasions but I blew it off as a seat or clutch switch. Well today it happened to me an best I can tell it’s probably a sticky ignition relay, (dash is dead, no power anywhere) 20 mins later starts up fine. My question, Is there a relay bank I can get to or is it all in the cpu?
/ Intermittent dead ignition #2
Have you tried cleaning the ignition switch? You can try spraying some electrical contact cleaner into it and see if you get anything. I replaced the ignition switch on a 20 year old tractor (stored inside) that had intermittent hit or miss, never had anymore issues.
Thanks, I tried to test, but so far every time I do it’s working fine. I’ll look into it a bit more
GENERAC 80KW PTO POWERED GENERATOR (A64278)
GENERAC 80KW PTO...
CATERPILLAR PC306 PLANER (A65053)
CATERPILLAR PC306...
BUSH HOG 4R48" BEDDER (A64278)
BUSH HOG 4R48"...
2019 GMC SIERRA HD 3500 (A63569)
2019 GMC SIERRA HD...
CATERPILLAR D8T CRAWLER DOZER (A64279)
CATERPILLAR D8T...
2022 EZ-GO ELITE...
