My Golf Cart Top -> Tractor Top build
/ My Golf Cart Top -> Tractor Top build #41
If anything ever happens to my canopy I'll be replacing it with a golf cart top for sure. It might even look less goofy on my tiny tractor!
I'm sure I could come up with a way to mount it with the existing mounts.
/ My Golf Cart Top -> Tractor Top build #43
Hey there is nothing wrong with that canopy & it looks pretty good & it beats no canopy at all & it's functional & it looks like You'll be in good shape as far as bracing for a replacement :cool:.
/ My Golf Cart Top -> Tractor Top build #44
I'm looking for brackets myself..... :unsure:
The only thing I might suggest is try & find aluminum brackets & braces & tubing & find a canopy that will work with your rops bar & design everything around it & the aluminum is a weight saver & might be cheaper than metal or steel & use square tubing:cool:.
/ My Golf Cart Top -> Tractor Top build #45
Oh I'm quite happy with it, and the $3XX was a drop in the bucket on my whole financed package. I just love me some low budget DIY stuff that turns out great!
Several have exclaimed that it looks silly, but I'm not interested in my tractor winning any beauty pageants.
I wanted my tractor to be 100% how I want it the day I took ownership. I tend to always buy minimally up front and upgrade later as funds allow. I didn't want to do that this time.
/ My Golf Cart Top -> Tractor Top build #46
I'm guessing your going to put this on your M-F 2410:unsure:? Look at replies from other TBN members & there pictures that should help You with how to proceed with how You want to do your bracing:cool:.
/ My Golf Cart Top -> Tractor Top build #47
Price update on golf cart canopy I was last at $337.00 for the project, I had to get another wiring harness & decided to add side view mirrors to the forward brace new total at 365.00 & project is not completed, I'll post pictures when completed of the led lights working as well as the final wiring hook up stay tuned;).
/ My Golf Cart Top -> Tractor Top build #48
Hey guys It's all done The only addition I put on was a old Dremel case to run excess wiring,relays & fuse blocks in & it can be opened & closed as needed & I drilled in drain hole it the bottom & holes for the wiring looms to go in & out :cool: The pictures IMHO are not that great I took them with my lap top & the hardest part of the whole project was the wiring & routing it to where there would be no issues clearance or rubbing against branches etc. & the radio I bought was way better than I thought it would be & the tractor engine could not drown outIMG_20210723_193809.jpg&
IMG_20210723_194325.jpgIMG_20210723_193847.jpg the radio period(y).& the mirrors are installed.
/ My Golf Cart Top -> Tractor Top build #49
I know that this is an old thread, but it still warrants a look. I like it. Considering how much tractor canopies cost, this is a very cost effective alternative. Very cool.
/ My Golf Cart Top -> Tractor Top build #50
Thanks it's still holding up quite well, & everything is still working, Led lights, & the radio.
INGERSOLL RAND  G25 GENERATOR (A58216)
INGERSOLL RAND...
Year: 2015 Make: Ram Model: 5500 Chassis Vehicle Type: Truck Mileage: Plate: Body Type: 2 Door Cab; (A55852)
Year: 2015 Make...
HYSTER S60FT STRAIGHT MAST FORKLIFT (A59823)
HYSTER S60FT...
Kubota L4701 (A53317)
2025 Pabreak 80in. Bucket Skid Steer Attachment (A61567)
2025 Pabreak 80in...
2018 RoGator 1100C (A61307)
2018 RoGator 1100C...
