kfanta
- Joined
- Jul 2, 2021
- Messages
- 5
- Tractor
- IH 424
I am looking to update the main cylinders on my front end loader. The previous owner put on the Front End Loader and while it overall works great the lift speed is slow. I believe this is because the tractor diverts 1/2 the flow to the power steering which means I get about 4.5 - 5 gpm going to the FEL cylinders. The current cylinders are a 3” bore and have a retracted length of about 37”. While I can find matching items. The problem is where the cylinder will connect to the load and loader frame. It looks like I would need to go with Tang Cyclinders to fit the mounting points
My thought is that one way to speed up the lifting process is to go with a smaller bore cylinder, but I am not sure how much lifting capacity I would loose. The heaviest thing I lift is I attach a bale spear to the front of the bucket (so the bucket stays on) and I will haul 1000lb square hay bales (as you can see in the pics it has a rather large bucket 7') I would still like to be able to manage at least that. I know that the farther out you go from the lifting point the more force you need, but I am not sure how to figure that out.
It looks like 3” bore uses about 3.4qts of oil for each cylinder where as 2” uses 1.4qts.
Can someone help me figure out a good replacement Loader Lift cylinders that will still give me plenty of lift capacity and maybe speed up the lifting process? Or conversely my only other option is to do a PTO Hydraulic Pump with separate reservoir. But then it makes it trickier to still be able to use the FEL and use the PTO for equipment that needs it. It would get my GPM up there.
Hopefully the attached pics can give you some idea on what I am currently running and approximate measurements.
The current cylinder which has an outside diameter of 3” is 37” or so retracted. Based on the mounts at either end and how narrow they are it looks like I would need to go with a Tang cylinder. I am wondering how much lift capacity I would give up going with a 2” bore? Also I am guessing because it would require 1/2 the oil to fully extend it should lift faster?
My tractor is an International Harvester 424 Gas engine. I would appreciate any thoughts or advice.
