NH 565 twine, sisal or plastic?
/ NH 565 twine, sisal or plastic? #1
Happy Gilmore
Southeastern, MA
Ford 5610 Ford 4630 Ford 3930 MFWD w/ 7310 loader Ford 3930 Kubota BX1500 Kubota RTV 900XT Kubota F2680E 72"RD Ford 4610 Kubota KX121-3
Hey guys, I'm down to my last two rolls of NH sisal twine on my 565. I've been thinking of switching over to plastic. What are your thoughts? Does it knot and cut well? Pros / cons?
/ NH 565 twine, sisal or plastic? #2
I've always preferred sisal, but it's just gotten so expensive this year, I've switched to plastic with no problems. However I use a New Holland round baler, I don't have any experience with square balers. Obviously, I can't tell you how it knots, but I've had no issues with it cutting. My friends with square balers are all using plastic now, and I haven't heard of anyone having any issue with it.
/ NH 565 twine, sisal or plastic? #3
If the twine knives are sharp, the change should be seamless. New Holland 500 series balers come equipped with billhooks designed to tie plastic twine. Older NH balers should be retrofitted, especially if the lighter, thinner 130 lb plastic twine is used. I prefer 170 lb knot strength plastic twine for small squares.
/ NH 565 twine, sisal or plastic? #4
I fought the ol' NH 269 to a standstill on tying. Finally got poly to tie a knot, had to give up on the the Sisal for a while. I really want to switch back to the Sisal. Not that I'm Greenie extremist, but, I really don't like the plastic all over my field ( the little knot ends) and the people I sell too say they prefer Sisal twine. bjr
/ NH 565 twine, sisal or plastic? #5
I am still using sisal for square bales. I went to plastic a few years ago for round bales - I keep outside, covered but on the ground, so the plastic twine helps a keep the bales in shape and prevents a lot of loss. But other than that, I hate plastic twine. I carefully take it off every bale I fed (I never bothered with sisal) and pick up every scrap I see. But no matter how careful I am, I still find pieces here and there, wrapped around the rake teeth, in the manure. Drives me nuts. So I'll stick with the sisal for square bales, even though it costs a bit more. I buy whatever is cheapest and I can count on one hand (even if I was missing three fingers) the number of knots my good ole 311 has missed...
Point taken on the having to pick it up or else, I can imagine the problems. I make a point to always pick up and dispose of twine, even with sisal, I can be a little OCD. I guess I can buy a couple rolls and give it a run.
/ NH 565 twine, sisal or plastic? #7
i have a NH 565 square baler and had problems with the plastic knotting. the sisal does very well in my baler. never have any issues with it knotting. other than running out of twine.
Dan, any idea what caused the knotting issues with plastic? Did you correct the issue or give up on it?
/ NH 565 twine, sisal or plastic? #9
Dull twine knives and or insufficient tension at the twine disc/twine holder are common and correctable concerns when using plastic twine, particularly 130 lb knot strength plastic twine.
/ NH 565 twine, sisal or plastic? #10
we solved the issue finally, the ceramic piece the twine feeds through had developed a lit notch in it from years of the plastic running trough it. we changed those and never had any problems. the guy that works on my baler said that the sisal would always do better in that particular baler. i believe the notches in those pieces was causing to much tension on the twine causing the knot to not form correctly.
/ NH 565 twine, sisal or plastic? #11
Hi, I’m new to baling hay (always worked the pick up crew side of things in previous baling experiences) and to this group. Sorry to bother you in an old thread but your experiences with sisal seem relevant. Bought a NH 565 baler from a reputable dealer of used equipment, who told me to use only 9600-170 poly twine. I really dislike the poly twine as it ends up everywhere and doesn’t degrade well. Point well taken that many buyers don’t want poly twine. Found some Lincoln 9000-190 sisal twine online. What issues might I encounter if I switch to sisal? Would I need to make adjustments to baler settings? Is it that big of a difference? The seller probably won’t support the baler if I switch and I know nothing about troubleshooting. Have manual , reading.
/ NH 565 twine, sisal or plastic? #12
My older MF120 square baler has used both in the past seamlessly. I usually utilize Sisal 9000 but could only find Sisal 7200 this year. I have to wait until 2nd cutting to get into the new rolls. I don't think you will have a problem. I knew nothing about Haybines, Rakes, and Balers until I had to buy my own equipment. Read the manual and watch You Tube. Around here TSC & Rural King have a good selection of twine with Rural King having more. Good luck.
/ NH 565 twine, sisal or plastic? #13
Thanks! Have a great day.
/ NH 565 twine, sisal or plastic? #14
565's usually have 3 part twine discs that will run either poly or sisal and case hardened bill hooks (which are required for poly) anyway.
You can run whatever you want in a 565 or later.
/ NH 565 twine, sisal or plastic? #15
Sure seems like we just covered this exact same baler and situation in another thread this week . . .
jmhinpa, In both of your posts, you expressed concern that your dealer "probably won't support" your baler if you switch to sisal. The sisal won't damage anything, so I think the worst that could happen with your dealer is he'd tell you to switch back to plastic if you have knotter problems. (He might say, "I told you so.") Otherwise the "support" will be the same. You won't be voiding any warranty, will you?
Around here, used equipment doesn't come with much of a warranty. If a dealer says it will tie a knot, they'd stand behind that but wouldn't really guarantee that something won't break next week.
/ NH 565 twine, sisal or plastic? #16
I've always said that the guy who designed the knotter assembly was wacko anyway. Have the knotter video that JD put out some years back and the more I watched it, the more confused I got.
/ NH 565 twine, sisal or plastic? #17
Not that I have a square baler anymore because I just sold it but I always preferred poly over sisal because sisal bales don't store well. Mice love to chew on the strings.
One thing I will caution everyone about and that is, don't ever leave any poly stings in the grass and run your mower over them. I guarantee they will destroy the spindle bearings on your mower in short order. Been there did that.
/ NH 565 twine, sisal or plastic? #18
Good points, thank you!
/ NH 565 twine, sisal or plastic? #19
True! I like your tag line at the bottom. No many are haying.
/ NH 565 twine, sisal or plastic? #20
Thanks, good to know
2017 ADDCO ROAD SIGN DH100-ALS (A60736)
2017 ADDCO ROAD...
Bobcat S740 (A57148)
2001 Kubota L3300F 35HP Utility Tractor with Caroni TC710 6ft. Rotary Brush Mower Attachment (A59228)
2001 Kubota L3300F...
2018 PJ TRAILER 32FT GOOSENECK TRAILER (A58214)
2018 PJ TRAILER...
2014 Chevrolet Silverado 3500 Crew Cab Utility Flatbed Truck (A60352)
2014 Chevrolet...
2013 Chevrolet Silverado 3500HD Enclosed Service Truck (A60352)
2013 Chevrolet...
