Tiller - Slip Clutch
/ Tiller - Slip Clutch #1
Glenn67
Mahindra 1815 HST
Good morning all,
I purchased a Mahindra 1815 HST from a friend a while back and have a question.
It came with a 50" rototiller and when I use the tiller it continually pops the clutch,
I have read that you need to run a slip clutch when using these implements, does
anybody know if this might help my situation?
Thank you for your suggestions.
Glenn
/ Tiller - Slip Clutch #2
Did you mean to say it has a shear bolt and keeps breaking it?
I think most tillers will use a slip clutch driveshaft. It is equally important to make sure it will slip to protect the tractor.
I just loosened the bolts on mine and slipped it then adjusted them back. I am going to draw a line on it with a grease marker to make sure it will slip.
When I got my tiller the slip clutch was tightened all the way down and rusted together. I had to remove the bolts and tap it apart with a hammer.
/ Tiller - Slip Clutch #3
A slip clutch need to be spun regularly. I spin mine yearly on my slip clutch equipped implements. I use a Torque wrench to reset them by locking the driveline with a suitable bar and setting the breakaway torque to 200 foot pounds. Your breakaway torque value should be listed in the manual that came with the tiller.
If it's breaking a shear bolt, the breakaway torque is set too high. It should slip before the shear bolt breaks (if you have one).
/ Tiller - Slip Clutch #4
Its my observation from many yrs operating/repairing farm equipment that slip clutch maintenance is one of the most overlooked component on equipment servicing.
/ Tiller - Slip Clutch #5
That and starting batteries and their (often corroded) connections.
2022 EZ-GO ELITE...
2015 Mack GU713 T/A Day Cab Truck Tractor (A64556)
2015 Mack GU713...
2017 WEILER P265 ASPHALT PAVER (A65053)
2017 WEILER P265...
2014 Ford Transit Connect Van (A61573)
2014 Ford Transit...
2007 Western Star 4900 SA Tri-Axle Wet Kit Day Cab Truck Tractor (A61573)
2007 Western Star...
2018 BOBCAT MT85 STAND-ON SKID STEER (A65053)
2018 BOBCAT MT85...
