Chains Turnbucklles b7500
/ Turnbucklles b7500 #1
Allen bassin
Kubota 2003 b7500
Is their a good aftermarket replacement ty.
/ Turnbucklles b7500 #5
Allen - I don't believe that you will find a Kubota telescoping stabilizer kit for the B7500. My local dealer"s whole goods salesman could not find one. Messicks told me they do not have such a kit for the B7500, although they are buying and selling locally-made conversions for other B-Series models. You could build your own from Kubota parts for other models, but it gets pricey IMHO. I came up with over $360 in parts without misc. pins, washers, nuts. One issue is that the B7500 uses different brackets ($52 ea. X 2) and "bolts" ($21 ea. X 2) than the models that were upgradable to telescoping stabilizers. This conversion will also require disassembly, bracket removal and bracket replacement of the mounting shaft between the lower lift arms.
A much better solution IMHO is to contact Mark Hodge at www.stabilizers.rocks for a quote. I have a complete kit for my B7500 on order for $210 delivered. Unfortunately, my build date will probably be late next winter.
Best wishes!
/ Turnbucklles b7500 #6
Are you sure about that web site address? it doesn't appear to be correct.
Thanks
2004 Mack 613 Concrete Mixing Truck (A64194)
2004 Mack 613...
2018 Chevrolet Impala Sedan (A64557)
2018 Chevrolet...
2020 CATERPILLAR 279D3 SKID STEER (A65053)
2020 CATERPILLAR...
(8) Used John Deere Hydraulic Cylinders (A65640)
(8) Used John...
2007 FREIGHTLINER CL120 6x4 T/A DAY CAB TRUCK TRACTOR (A59914)
2007 FREIGHTLINER...
53ft Reefer Trailer, VIN # 1GRAA06267S701883 (A65563)
53ft Reefer...
