Bush hog blade stopping
/ Bush hog blade stopping #41
IMHO & yrs of experience repairing/operating farm tractors if hyd actuated pto shaft speed slows in a greater % than engine speed drops or pto shaft stops while engaged then pto clutch/control valve needs attention.
Round bales come in many different widths/diameters/weights! what width/diameter/weight were your 110 rd bales?
I agree. If the PTO stops under load, something ain't right with the PTO valve and/or clutch pack. The PTO clutch pack in good working condition is able to stall the engine if there is enough load on the PTO for that.
/ Bush hog blade stopping #42
So Yanmars, you have received lots of diagnostic advice, and operating advice. Are you going to try any of them? Inquiring minds want to know:cool:
Was gone for several days. Will read up and try a few things tomorrow hopefully. The front of the mower is already lower than the rear.
/ Bush hog blade stopping #44
If the grass is heavy and high, make the rear of the mower quite a bit higher than the front.
Just an update. Did not try to mow, too wet. Another issue arose. The tractor would not start. Looked at the owner's manual. Said one needed to be seated on the seat or have the parking brake on to start it. The PTO was off and the tractor in neutral. Put the parking brake on and it immediately started. However even while seated on the tractor when the parking brake was released it stopped within 2 seconds.
The problem has to be in the weight/seat issue.
Tried another tact. Started it with the brake on, released as much tension as I could on the brake lever. Put the tractor in drive and pressed on the forward travel feed pedal. Would not move forward at all. Probably a safety feature if it is on.
So it will start and run but only if the parking brake is on, release that and it will stop.
Do not have a parts manual or repair manual but to me the issue seems related to sitting on the seat/weight. Anyone ever have this problem on a New Holland TC 40? I did post in the New Holland section also. Thanks
/ Bush hog blade stopping #46
Have not had on a New Holland but did in the Massey. It was a broken seat safety switch. As a temporary fix, I found the wires and jumped them with a wire nut. Then bought the proper switch, replacing it and the broken mechanism. Seems to me someone was standing on the seat and broke the switch.
Don't know if New Holland does it the same as Massey but my home Deere lawn tractor has a similar switch and setup.
Got the seat issue fixed so I can now operate it but still the mowing problems. It will mow the previously mowed low grass, not the tall stuff. We will get it done what absolutely needs to be done and await my tractor/mower when the O ring gets in.
/ Bush hog blade stopping #48
S
I was mowing grass with a 5 foot light duty King Kutter brush hog using a 40 horsepower NH tractor. It cut well in areas I had cut earlier this Spring but when it got into 2 foot tall grass (not that thick) it caused the blade to nearly stop but enough it did not cut at all. The mower has always been greased, the shear bolt was not damaged or broken. The blades are dull. When I would get back to the prior cut grass the blades would pick up speed and cut again but it had nothing for the taller grass. The tractor was moving at slow speed with engine RPM near 2500.
The problem is most of the grass is tall as my main tractor and mower have been down for 3 months waiting for an odd sized O ring. Really need to mow the tall stuff with what I have. Any thoughts or suggestions?
Sounds like that thing has a keyway sheared on the gear inside the gearbox.
/ Bush hog blade stopping #49
S
So explain why the PTO shaft is slowing down same as the blades....yet the engine RPMs don't?
/ Bush hog blade stopping #50
What's so confusing to you about Unclewillie's post? Seems pretty clear to me. Some tractors have a key, usually on the hub for the one way clutch, on the PTO drive line inside the transmission. If it's sheared, the mower would stop spinning once it hit the grass and the engine RPMs wouldn't change. It might create enough drag to spin the mower in the up position.
/ Bush hog blade stopping #51
I was in the belief that the tractor has no issues, therefore it's a problem with the rotary cutter. It's possible the hub that has the large bolt that the blades attach to has stripped out splines or shear key allowing the blades to turn until a certain amount of resistance then the blades hub simply spins a On the shaft.
/ Bush hog blade stopping #52
I'm the case of pto shaft slowing same as the blades on an hst first thing I would do is clean the hydraulic fluid screen and filter, if that don't work i would worry if an electric clutch is involved.
/ Bush hog blade stopping #53
Pretty sure he's talking about the rotary mower's gearbox.
/ Bush hog blade stopping #54
He said a key on the gear in the gearbox. There is nothing wrong with the mower
/ Bush hog blade stopping #55
Yes. It was later in the thread after several people were asking questions that he said he can physically see the pto shaft slowing down. He has a problem with the tractor
/ Bush hog blade stopping #56
Very sad anyone has tractor trouble, like a hurting friend.
/ Bush hog blade stopping #57
Many moons ago I was chopping hay for a farmer
and his tractor was 100 hp IH and the chopper was IH also got into some really think alfalfa clover tractor started to snort then stopped dead. What happened was one of the hydraulic hoses broke and farmer took it in for repair instead of buying a new hose that would be long enough to replace the broken hose but no he just switched the hoses! bummer really jammed the chopper up!
willy
/ Bush hog blade stopping #58
The king Kutter has a center piece that spins causing the blades move out. The nut that holds the center piece in place has a pin to keep the nut from coming off by accident. If this nut has loosened the gear box will turn but the blades are not being forced out because the center plate is not spinning.
If you have the tractor off and in gear with the PTO engaged you should not be able to turn the plate. The nut should be on tight. I have indicated the nut I am talking about.
/ Bush hog blade stopping #59
There is nothing wrong with his cutter
It has a new hydraulic filter and fluid about 5 hours ago.
IRANCH IRGC40 ELECTRIC SCOOTER (A64280)
IRANCH IRGC40...
New/Unused 3 Point Hitch with Ball/Flat Hitch (A65583)
New/Unused 3 Point...
28ft Metal Frame Trailer (A65563)
28ft Metal Frame...
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
Interstate 20ft Tilt-Deck T/A Flatbed Equipment Trailer (A64553)
Interstate 20ft...
CATERPILLAR D6N LGP HI-TRACK CRAWLER DOZER (A65053)
CATERPILLAR D6N...
