John Deere relife program
/ John Deere relife program #1
mred2
West Alabama, USA
iseki tl3200, JD 450H dozer, LS XR4150, Genie Z34/22N lift
There is a program in Deere construction equipment. It is powertrain relife. They replace the Transmission, engine, axles and other parts on the equipment and give it a 3 year warranty. With construction being used as hard as it is and the cost of new equipment, it looks to be a good solution. I was wondering if anyone is planning on doing this with farm equipment. If might work with large equipment, not so much with CUT.
/ John Deere relife program #2
I know why they are not doing it with the CUTs, just too many of the Gray Market Yanmars would dip into that program in a heart beat. It's not a few hundred mind you, it's in the 10s of thousands.
HOWEVER, in another re-life activity, those with JD/Yanmar CUTs are now seeing the CUT community removing the dead engines and attaching the Harbor-Freight engines with a direct chain to the geared tooth fly wheels. Many of the CUTs are 30Hp or less. On the 12 to 16Hp range, the H-F engines are improvements. EZ to wire the electric start to the key switch and a mower cable to the throttle cable.
People have also done this to Ford 8Ns, Case, and Massey machines. It's a retro repower method that will not break the bank either.
John Deere D110 Riding Mower (A62679)
John Deere D110...
2014 Ford F-150 4x4 Ext Cab Pickup Truck (A64194)
2014 Ford F-150...
2014 JOHN DEERE 648H SKIDDER (A62129)
2014 JOHN DEERE...
New Landhonor Skid Steer Utility Hitch Adapter (A62679)
New Landhonor Skid...
2015 Ford F550 4x4 with 37' Bucket (A62613)
2015 Ford F550 4x4...
Carryall 1700 4x4 (A61574)
Carryall 1700 4x4...
