Backhoe How do you dig a trench with a CUT backhoe?
/ How do you dig a trench with a CUT backhoe? #1
boostmg
Pennsylvania
Branson 3620 TLB Hydro
Ok so I have to dig trenches. I already dug one, and managed to get myself stuck.
I think my machine with BH, Loader, & Loaded Rear Tires weight 7800lbs. I always saw people digging by straddling the trench. No matter what i need a way to cross this trench. So if i straddle it, then i can't really get off it unless i use my hoe to crab myself to the right or left moving the rear tires - not sure if i should be doing this or not.
The other option i saw on here somewhere was dig from the left side, then dig from the right side, then back up to the trench where it isn't dug out yet and connect it by just backing the tractor up to the trench and using the hoe at 180*.
I'm really just asking to see how you all do it.
/ How do you dig a trench with a CUT backhoe? #2
What are you digging for? If running pipe or conduit, some will dig and lay at the same time more or less. That way you can fill behind you. Dig 50', lay 30' of pipe, fill and cross over the filled section.
Others will lay heavy timbers and plywood over a section to drive over.
/ How do you dig a trench with a CUT backhoe? #3
In my location you can't dig very far until the vibration from the tractor causes a cave-in where you just dug, so lay pipe and backfill as you go is the rule around here.
Its actually an open trench ... which will have a pipe in it as well for crossing. but only in one section open trench > pipe > open trench
essentially drainage ditches/swales/ except im just doing a trench
/ How do you dig a trench with a CUT backhoe? #5
Sounds like you’re doing it backwards? I dig, drive forward, dig, repeat and never straddle open trench. Few exceptions when going up to a a wall or whatever.
Yea what your saying is fine ... but imagine u have to dig a trench from one lake, to another lake ... u cant exit into the lake!
its the "exit" that im looking for advice on
/ How do you dig a trench with a CUT backhoe? #7
You can't dig going forward until right at the lake then move the tractor to the side to finish?
/ How do you dig a trench with a CUT backhoe? #8
I once trenched between buildings and needed the entire trench open before backfilling.
I started digging from the wall of one building toward the center. Before getting too close to the other building, I drove forward, turned the tractor around, and started digging from the wall of the second building toward the center. I wound up with a continuous trench between the buildings with the tractor straddling the trench in the middle.
I manually/hand backfilled the trench just enough so I could drive the tractor across the refilled trench. Some dirt in the trench, then boards and plywood on top. I drove the tractor out and used it to backfill the rest.
/ How do you dig a trench with a CUT backhoe? #9
That makes it a lot easier. Dig from one end to beyond where the pipe will go. Lay the pipe and cover it so you can cross over at will. Then dig from the other end back to the pipe.
lol this is really smart!
yes i think this is one of the methods i had in mind
/ How do you dig a trench with a CUT backhoe? #13
i have always straddled open trenches with backhoes and excavators. only issue you will have is a bit of fill falling in holes. sometimes you cant just dig from both ends and meet in the middle, especially on my real long runs of wire . we install the wire in the pipe as we lay the pipe, so we dont have to pull it in later. hard to meet in the middle that way without damaging wire.
i have dug miles of trenches over the years. i start at one end and dig all the way to the other end while moving rig foreward. when i get to the end i drive over the open trench going in the opposite direction and complete the trench. at this time i either drive off the trench and hand dig the collapse area ( i swing rear tires off trench , and can use loader to keep front tires out of trench....or if on excavator i just drive out). the other option is leave trencher straddling the trench, install pipe and wire by pushing it under machine while standing clear of underside, then simply filling trench.
I definitely want to be able to swing my rear tires over the trench. Basically put my loser bucket down, push the rear up w the boom, and swing sideways.
I guess I’m just worried if the machine can handle it w loaded rear tires. But quite honesty of i can’t do that then i feel the machine would be disappointing to me.
/ How do you dig a trench with a CUT backhoe? #15
Try it on flat ground first. Maybe mark out a “trench” with paint and get good at it beforehand. The tractor should do it easy.
/ How do you dig a trench with a CUT backhoe? #16
Try it out. Draw your "ditch" on the ground and see if you can straddle it and swing the tractor out & over the pretend ditch before you actually start digging.
My backhoe doesn't like to lift the rear of the tractor up - not sure if it's a low relief setting on the BH valve or not yet (need to test that) but it's a heavy unit and the tires are filled with beet. Depending on the soil type, sometimes I have to push down on the dipper to get my rear up in the air (eg to eliminate sideways tilt), but I've still managed to scootch over a ditch like what you need.
/ How do you dig a trench with a CUT backhoe? #17
Ive never done it but have seen it done all the time. Using the FEL bucket low get the nose over the trench, the FEL bucket will keep the tire from falling in. Then use the backhoe to pick up the back end, keep the stabilizers low, and straddle the trench. Sounds easy but I bet it takes some technique.
I’m defiantly going to try it on flat ground. When i got stuck i was doing it but i didn’t fully raise my tires off the ground bc i was nervous.
im trying like mad to research specs to see if doing this is “within the limits” of the tractor.
the best I’ve been able to find so far is “boom lift capacity” but no idea how that translates into pushing the rear of a tractor in the air.
i was also trying to thing about the area that gets stressed in this situation and i believe the pivot pin at the base of the boom is where all that stress goes?
Im new to hydraulics and heavy machinery but not new to machinery. I sleep a lot better when i know whatever i do is within spec, this one just seems hard to find clear info on.
/ How do you dig a trench with a CUT backhoe? #19
SNIP....
I must have missed it when you said which machine that you have. Anyway, here are my thoughts after many hours on a hoe.
It depends on the machine. What you are describing is a common move with commercial and semi-commercial TLBs. There are a ton of U-TUBE videos that are fun to watch showing how to cross a ditch that way.
We have a JD310 and a Kubota M59 and either will easily lift the rear of the tractor with the hoe for re-positioning. We do it.... all backhoe operators do it all the time without thinking much about it. I do it sometime just to clear a shrub so that the outriggers or tires don't destroy the landscaping It's worth noting that the backhoe mount on both thes TLBs is heavily overbuilt, and TLBs don't typically run fluid in the tires.
When you are learning, go very slow with the swing movement & keep it low. Lift the outriggers just clear of the ground. Keep the BH bucket curled in a little with the flat side down so it can slide as it needs to.
A couple of things to remember: for that move you either put the FEL bucket flat on the ground so it works as a sliding pivot or raise it so the front bucket is off the ground allowing you to pivot around the front wheels. DO NOT try to make that move with the cutting edge of the FEL bucket down digging into the ground. You can warp the FEL that way.
I certainly wouldn't make that move a 3pt mount type backhoe and would think twice and study things well before doing that move on any Ag tractor - even those with a subframe. I also personally wouldn't do it with loaded tires, but I know some who do.
YMMV,
rScotty
I have a Branson 3620h w a bh250 backhoe. Based off my estimate the machine weighs 7800lbs.
bh is subframe mounted.
im looking at the manual right now and the boom pin is 32x206mm and the swing frame pins are 45x107mm. I am just guessing that is where most of
The stress would be applied.
so far i managed to find a case backhoe boom pin and that is 2” in diameter and if that machine weighs 15000lbs they reverse math means potentially a 1” pin would be the equivalent for my weight.
doing my best trying to problem solve but i would hope my machine is also overbuilt as that’s what i like and usually buy.
it’s just the lack of material out there on this topic is tough.
KJ K2825 28'x25' Metal Workshop (A60463)
KJ K2825 28'x25'...
2013 GREAT DANE 53X102 T/A REFRIDGERATED TRAILER (A59906)
2013 GREAT DANE...
24in excavator tooth bucket (A61307)
24in excavator...
2021 MULTIQUIP WHISPER PORTABLE AC GENERATOR (A59823)
2021 MULTIQUIP...
2025 Pabreak Hydraulic Vibratory Roller Skid Steer Attachment (A61567)
2025 Pabreak...
FLAT BED (A60736)
FLAT BED (A60736)
