FEL removal and ride quality
/ FEL removal and ride quality #1
LabLuvR
Gold Member
SC
Kubota MX5400
I bought a new Kabota MX 5400 last year. I really love the tractor but the ride was horrible. Every little bump seem to go through my spine.
The other day I decided to take the loader off for some tight bush hog work. Immediately I can sense a much softer and gentler ride. I still feel the bumps but not nearly as bad as before. Is it my imagination or did the FEL affect the ride quality that much? And if it did,why? Thanks
/ FEL removal and ride quality #2
There are a lot of things we'd need to know for good feedback. Bottom line yes, taking weight off the front end will make it seem smoother. What you're doing is reducing the work the small front wheels are doing and transfering more work to the larger rear wheels which are better at smoothing things out. Typically if I'm brush hogging I like to take the bucket off but keep the FEL on so I run the fell into something rather than the tractor and get the material layed over better so it doesn't drag on the tractor as badly.
/ FEL removal and ride quality #3
I just remove the bucket on mine. I have also started mowing in 4th gear low range; much improved ride and cut with the 12ft batwing.
/ FEL removal and ride quality #4
My JD 4120 has a heavy duty bucket and I always take that off when I am bush hogging large areas. That definitely makes for a quieter, smoother ride. It takes me under a minute to drop the bucket, and the ride is nearly as good as when I remove the whole loader (20 minute job).
Yes I was able to go up into a higher gear due to the soft ride as well.I have a heavy duty bucket as well maybe that’s the problem more than the loader itself. Thanks for the idea.
/ FEL removal and ride quality #6
Interesting. I find, on my Mahindra 3015 (30HP) that the heavy 66" bucket tends to smooth the ride on the road or street. The industrial tires on the front are stiff as a board, even with very low psi, and the extra weight of the bucket seems to counteract that. I run very low psi in the rears also with no fluid and normally have an attachment of some weight on the 3PH.
/ FEL removal and ride quality #7
I remove the entire FEL when I mow with the bush hog for a smother ride. It takes about 5 minutes.
/ FEL removal and ride quality #8
With the Kubota, I just remove the bucket. With SSQA it takes less than a minute, and really improves the ride. It takes out that bounce and bang over rough roads.
On the JD, there is no SSQA. The pinned on bucket stays mounted. But it has the optional "comfort ride" which stores the bounce energy and smooths out the ride. Of course it's a couple of thou for that option...
/ FEL removal and ride quality #9
Adding the Kubota soft ride to the M59 FEL made a huge difference in ride quality but also helps in component wear from reducing the shock load. NOS from eBay $200 and about $150 in valves, gauge and hydraulic line/fittings to modify for my application. With a valve to turn on/off and gauge to monitor FEL hydraulic pressure can see and feel the damping effect. Been one of my favorite modifications.
Bush hogging is a mixture of the grapple on and off. Trees here grow like weeds so there is always trees/limbs down to clear. Some pushed back into the woods, some carried to house size tree gully composter pile.
Use a Kubota B26 with a 6’ finish mower and drop the bucket/grapple for clearance, weight on slopes and ride. Hope to add a soft ride system someday. Neither tractor has a removable FEL.
/ FEL removal and ride quality #10
It's because you had just the right weight front to back and had a teeter totter effect.
Aaron Z
/ FEL removal and ride quality #11
I've noticed on my 5800 with FEL and BH attached, it bounces a lot. When i fill the bucket with orange mud it rides like a dream.
/ FEL removal and ride quality #12
I got three words...Kubota Shockless Ride. Best money spent since the true third function valve.
/ FEL removal and ride quality #13
... Every little bump seem to go through my spine.
The other day I decided to take the loader off for some tight bush hog work....
I have a Kubota L3710 (L4600 physical size), and recommend the following, some is a summary of what has already been posted.
1) Remove the whole loader before shredding/mowing, as you did, but -
2) for less time and partial benefit, remove just the bucket. Kubota has some quick attach pieces available if yours has the bucket pinned directly to cylinders and arms.
3) Fluid in tires make a harsh ride. Fluid does not compress. I prefer to add weight via 3 point if weight is needed.
4) My rear tires are R1 and width is 14.9, which I keep at 8 to 8.5 psi. At this pressure, the tire lugs are flat on the ground with mower down, sidewalls slightly bulge when the mower is lifted, but the main point is that it improves the ride substantially. When I bought it from a dealer, they had the tires are more than twice that pressure which made the ride bouncy and harsh.
/ FEL removal and ride quality #14
When I switched from a 1975 International Harvester 284 to a Mahindra 2616 last year, I was amazed at how bumpy the ride was. I could drive the IH in fourth gear going up the driveway, but I never do that with Mahindra Baba.
Glad to read this thread. I'll try taking off the bucket when I'm brush-hogging.
/ FEL removal and ride quality #15
I remember when I got my new tractor delivered back in 2002, a Mahindra 4110 w/FEL. I drove it the 3 or so miles to our Co-op to get the rear tires filled with methanol mix with no implement on the 3 pt. The ride was terrible to say the least and the tractor had bad see-saw effect at road speeds, I'm sure from the FEL (bucket was originally pin on). After getting 55 gal of mix in each tire the ride back home was TOTALLY better. Just adding that weight to the tires changed everything.
2000 Bobcat 763 (A60462)
2000 Bobcat 763...
Ford 8210 (A60462)
Ford 8210 (A60462)
UNUSED ATS POWER ATS-PC90 HEAVY DUTY PLATE COMPACT (A64281)
UNUSED ATS POWER...
2019 International DuraStar 4300 26ft. Reefer Box Truck (A61573)
2019 International...
1999 Sterling L9513 Tri-Axle Roll Off Truck (A59230)
1999 Sterling...
2023 Caterpillar 259D3 Compact Track Loader Skid Steer (A64194)
2023 Caterpillar...
