New Member, New Owner of a 425
   / New Member, New Owner of a 425 #52
Here’s a dissected Power-Trac muffler, btw.
WOW! Looks like somebody at PT believes in the myth that engines like this need backpressure. This looks WAY too restricted to me. While a large header/exhaust pipe can reduce power at low RPM's due to reduced exhaust velocity and scavenging, a lot of back pressure is not needed in a 4-cycle engine. I'd be much more comfortable with Subaru's stock system since there was probably a degree of engineering applied to optimize flow velocity and scavenging. I'm not saying PT didn't optimize with this...but I doubt it given the use of square tubing and right angle turns. I have the same setup on one of my PT's...so, thanks for confirming my suspicion. I'm have a stock Subaru exhaust system around here somewhere if I didn't throw it away, which I probably did because I thought I'd never need it. This is before I bought another 425 with the Subaru engine. I better go look for it.
The stock Subaru pipes sweep up and out. I put a EH72 FI in my friend’s PT425, had to modify the engine cover so the hoop where the pipe exits is taller The pipe also had a bend and flange on the end I cut off and extended it with a straight piece. I found a tractor muffler on line, I needed an adapter because it’s inlet pipe size is larger than the Subaru pipe. The pic is from when it was still a work in progress about 4 yrs ago.
HYD AUGER W/ 16" BIT (A52708)
HYD AUGER W/ 16"...
Heavy Duty Solid Steel Skid Steer Mounting Plate (New/Unused) (A59225)
Heavy Duty Solid...
2014 Ford Fusion Passenger Car, VIN # 1FA6P0H77E5377755 (A56859)
2014 Ford Fusion...
JOHN DEERE 4760 TRACTOR (A52708)
JOHN DEERE 4760...
2017 Chevrolet 1500 Silverado Crew Cab Pickup Truck (A55973)
2017 Chevrolet...
KMC 4R STRIP TILL (A52708)
KMC 4R STRIP TILL...
