New garage time!
/ New garage time! #1,101
Any update on your Bobcat repower?
/ New garage time! #1,103
Glad to hear you're still keeping busy! That pantry work was probably nice to break up the monotony of the garage work. I wonder how much you saved in lumber and steel costs, building last year compared to this year.
/ New garage time!
My estimates say I saved about 30k on lumber by doing it last year vs this year considering we're seeing 300-400% increases in wood pricing. Which would have pretty much bankrupted me, i'd be stuck with a half of a building. I'm at the bleeding edge of my savings right now, i need to get paid to move forward.
/ New garage time! #1,106
Does that mean you got that all that done for $30K ?
/ New garage time!
I spent 14k on lumber, right now it's sitting at about 300%, that's nearly 45k.
To date i'm at 96k, I just added it up today. From the stone, buying the 24" bucket for the backhoe, buying the bobcat to do cleanup, concrete, block, stone, rebar, wire mesh, pex, lumber, steel joists, siding, garage doors, man doors, nails, screws, rafters, siding, roof panels, trim, and a bit of labor.
/ New garage time! #1,109
What is the current state of the Bobcat?
/ New garage time!
Haven't needed the bobcat yet so the bobcat isn't fixed yet. I've been on back to back projects with no down time at all even on the weekends. My kubota zero turn blew up end of last season and now spring has sprung, had to fix that. Turns out the hydro filter was at capacity and creating additional load on the mower, causing it to sevearly overheat to the point of popping the radiator. It would run loaded but not really reflective in the RPM, but soon as i hit grass. It was running very poorly, and couldn't tell why. 2 years on the filter and oil, and I've never had an issue like that before, especially in that amount of time. I started air filter, oil filter, oil, hit all the grease points real good, made sure everything was smooth. When it was the last thing to do i completely flushed hte hydraulic system and cleaned it out real good, and that ended up being the case.
Next is a race condition. I fix the ditch witch and trench electric, or I find a scissor lift for a reasonable price to do the roof. Biggest challenge for the roof is getting the panels up there. And trim. All that funs ****. I'm estimating 2 weeks given my work pace, which means rental is $2500 at the current local rates of about $175/day. I refuse to believe I can't find one for $2500 if I just watch the local ads.
There's the ditch witch. While plowing gravel I noticed something when I turned the wheel. The front axle didn't turn. It just shifted one way or the other, side to side. Get under it and realize that the plate pivot point was broken, axle is not attached to anything, just sliding about. So I have to figure that one out.
Next time I'll need the bobbcat is when I dig up the remainder of the concrete or do the stone driveway in 2b to prepare for the asphalt guys. So the jack hammer and old ass backhoe will also make a comeback.
/ New garage time! #1,111
That sounds about what I would have expected. So money wise you could have built "75%" of it this year and it would have cost an additional 25% this year compared to last just factoring in the higher lumber. Other things are up so maybe 30% more. I am looking at building a barn so curious where you came out. Thanks for the input.
/ New garage time!
Wood has dropped 400 points this week, the prices should be reflective in 2 months or so on the shelves if we're lucky. Lumber isn't moving as fast right now so they need to sell their expensiv elumber before they can buy cheap lumber and sell it at cheaper rates.
/ New garage time! #1,113
Thanks. 1x12 was $45, but 3/4 plywood was $57. And I wanted deeper shelves. So I ripped the plywood in half. I wasn't sure about the inside corner strength but it's shockingly sturdy. Everything is tied together with an absurd amount of screws so I think I'm ok.
You could always add a vertical support, at the corner where the 2 pieces of plywood come together. Canned goods get heavy.
/ New garage time!
One of the challenges has been how am I going to get these 13'x18" roof panels up to the roof safely and effectively. I was looking at bucket lifts or backhoe lifts or fork lifts but the roof is 25' off the ground and every option came short. So eventually I found scissor lifts and that seemed to fit the bill perfectly. Called up the rental place and 2 weeks was $2400. I said I'd let them know.
Hopped on the facebook marketplace since craigslist is all but dead. Scissor lifts were 5-6k all day long. "Ok half the price of a rental" but still not an easy to swallow pill. Then one popped up for $2500 that goes up 20' and I thought, this will be perfect. Called the guy, sent a deposit, picking up on friday.
/ New garage time! #1,115
Having your own is so much nicer than a rental. I use mine out in the mud by booming it down onto the trailer and pulling it around with my tractor.
/ New garage time!
Sure, but it's becoming a bad habit. I've bought a bobcat, ditch witch, air compressor, and now man lift for this garage. I did rent the jumping jack compactor. But yeah, I have big plans for this lift, and that's a good idea using it on the trailer so you can go off road.
When not in use I figure I can just park it in the back of the garage so I can use it to access the 2nd floor. I thought they all had 300-350lb capacity, but this thing is 750lbs, which is considerable. I think I'll really be happy with it(although the wife wasn't).
/ New garage time! #1,117
Since I started my six month barn/shop build a year and a half ago I have added a few necessary tools (two scissor lifts, a bunch of Makita and Dewalt cordless tools, a second tractor, a 30' gooseneck trailer, etc...). I heard one time that whoever dies with the most tools wins (as long as it was not a tool that killed them) so I am operating on that assumption. My wife, on the other hand, just hopes that she dies first so she does not have to deal with all of my "junk".
View attachment 700995View attachment 700996View attachment 700998
/ New garage time!
Seems like I can't see your attachments. But this was just the big stuff, got a full set of milwaukee m12 tools. I have nearly every tool in triplicate, my wife says when I die she's having a yard sale, everything $1 each. So if I die, it's in everyone's best interest to start searching for yard sales
/ New garage time!
Brought it home today. Exceeds expectations in every way. Except one. Insanely easy to bottom out. No ground clearance. Which means it'll be fun to move into position. Unloading I had a bit of a bouncing event and set off the out of level alarm, which disabled everything. Not knowing how it works it took some doing to get rolling again. Definitely not an off-road machine. Reading the manual max is 6 degree slope. Which is probably good for something as top-heavy as it is.
Then unloading I beached. Had to jack up one end and put 2x4's under the wheels so I could fully get off the trailer.
Still once I learn how to properly use it, and get things set up so I can move around, I think it will be an incredibly useful machine.
/ New garage time! #1,120
Heck, I'd consider using it as an elevator, parking it semi-permanently in the stairwell, and keeping the battery charged.
Good find.
UNUSED IRANCH MINI HYD THUMB (A62131)
UNUSED IRANCH MINI...
UNUSED SDLANCH SDLFP30 EELCTRIC PALLET JACK (A62131)
UNUSED SDLANCH...
2015 CHEVROLET 2500 HD CREW CAB FLATBED TRUCK (A62130)
2015 CHEVROLET...
UNUSED 2026 INDUSTRIAS AMERICA HYD TILT TRAILER (A60430)
UNUSED 2026...
(2) 330 GALLON POLY TOTES W/ CAGES (A62131)
(2) 330 GALLON...
UNUSED JCT QUICK ATTACH 60" PALLET FORKS (A62131)
UNUSED JCT QUICK...
