Compact tractor for grading long and steep driveway?
   / Compact tractor for grading long and steep driveway? #1
beeser
Bobcat CT2040
The Bobcat CT2040(HST) compact tractor that I just purchased is proving to be not up to the task of grading and maintaining my long and steep driveway. It seems anemic in power compared to my previous John Deere 855. I don't know if it's because of the increased weight of the Bobcat or gearing but I don't feel anything was gained with the purchase other than it's a new tractor. I may replace the Bobcat if something more suitable is available. Any suggestions? Smaller tractor with a more powerful engine?
   / Compact tractor for grading long and steep driveway? #2
Are you in low gear with 4wd engaged? Is it bogging down and not moving? Or, is it just too slow?
Mike
It bogs down to a standstill in high gear, moves along but struggles in mid gear and is excruciating slow in low. Performance is only slightly reduced in 4WD compared to 2WD. With any grading attachments installed I would have to use 4WD uphill so that has to be the baseline.
I really want to replace this tractor with something more suitable for my needs. I don't think the Bobcat is up to the task.
   / Compact tractor for grading long and steep driveway? #4
If you have a Yanmar dealer nearby check out
this tractor: YT3 Series | YANMAR Tractor
warranty is 6 years and maybe 2 year bumper to bumper warranty and if you sell with 2 year warranty
left you can transfer the warranty to new owner.
willy
   / Compact tractor for grading long and steep driveway? #5
40 hp should be plenty on that frame size. You should be able to pull a box blade in midrange. I think your tractor is not performing as it should. Forget hi range for any work.
   / Compact tractor for grading long and steep driveway? #6
A 40 hp tractor that weighs 2700 pounds base weight is fairly strong for its size. Either you bought a tractor that’s way too small or it’s not functioning properly. Based on the fact you even attempted to pull a blade in high range leads a strong possibility that user error is the problem here.
   / Compact tractor for grading long and steep driveway? #7
How steep is steep?
Haven't tried to pull anything with this tractor yet. It barely carries it's own weight up a hill.
   / Compact tractor for grading long and steep driveway? #10
Grading with what? Box blade. rear blade, land plane/ How big/ heavy ?
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2019 Chevrolet Silverado 2500HD Crew Cab Liftmoore 2700AR 1 Ton Crane Service Truck (A55973)
2019 Chevrolet...
TOOLBOX & AIR TANK (A58374)
TOOLBOX & AIR TANK...
2019 John Deere 1025R 24HP 4WD Loader Utility Tractor (A55973)
2019 John Deere...
72" General Purpose Skid Steer Bucket (A59076)
72" General...
CAT 312C EXCAVATOR (A58214)
CAT 312C EXCAVATOR...
