Compact tractor for grading long and steep driveway?
   / Compact tractor for grading long and steep driveway? #21
High gear on a HST is really only for flat ground. My Kubota has a two speed HST motor so it acts like a 6 speed. Even in M (high) it'll start to bog down if I push the go pedal to the floor on some of my steeper hills. If pulling a grading scraper I use M(high) to start off with but once I get some dirt built up I have to shift to M(low) and on occasion into L (high). I wouldn't replace what you have now until I was able to test out what ever you think you might need otherwise it may not meet your expectations. Since none of us are there to watch what you are doing we can only guess. My guess would be that 40hp may not be enough to do what you would like. I think I would be looking at something in the 60hp range or accept going at a slower pace.
2012 JOHN DEERE 13-INCH REAR WHEEL SPACER FOR 10 BOLT HUB (A55315)
2012 JOHN DEERE...
VERMEER FEED ROLLER (A58214)
VERMEER FEED...
1998 FREIGHTLINER FL50 SPORT CHASSIS (A56129)
1998 FREIGHTLINER...
2011 Ford F-150 Crew Cab Pickup Truck (A56858)
2011 Ford F-150...
2014 INTERNATIONAL  DURASTAR 26FT BOX TRUCK (A58017)
2014 INTERNATIONAL...
Moxy MT30S Haul Truck (A55272)
Moxy MT30S Haul...
