Loader LK 2554 and LK 3054 Hydraulic Pump Upgrade
/ LK 2554 and LK 3054 Hydraulic Pump Upgrade
I marked the first picture I marked the hoses and diverter knob.
P=Power to loader valve
T=Return to tank
PB=Power beyond from loader valve that feeds 3pt hitch
The knob is circled in green and needs to be all the way clockwise to feed the loader valve.
64560655-0904-44BE-B672-8F93EA0DD257.jpeg B55901AC-F1B9-4D6D-840B-35F0FA4B934F.jpeg
/ LK 2554 and LK 3054 Hydraulic Pump Upgrade #22
I put the pressure gauge on the curl function of the loader valve. I will have to take more pictures tomorrow but they have a couple different priority valves so yours may look different.
When you add a loader you have to turn the knob on the priority valve clockwise to direct flow thru the power beyond port. I will get a picture of that as well. Hope that helps.
Thanks for the response. Looks as though I have a lot to learn. I thought an addition of the loader would be pretty much plug and play.
No problem I am glad to help.
Can you post a picture of your loader valve? You should have 7 total hoses connected. 4 to the cylinders, 1 to the power in, 1 to the tank port and 1 from the power beyond port.
/ LK 2554 and LK 3054 Hydraulic Pump Upgrade #24
/ LK 2554 and LK 3054 Hydraulic Pump Upgrade #25
T=Return to tank
View attachment 700484 View attachment 700485
Sorry about the crazy pictures. My computer is acting up and having a terrible time attaching files. This is only one of several.
Can you confirm you have hoses correct?
P=Power in
T=Out to tank
PB=Power Beyond
/ LK 2554 and LK 3054 Hydraulic Pump Upgrade #27
Here are the 3 hoses that go down to the block on the tractor
2017 Versatile 260 (A60462)
2017 Versatile 260...
2002 Frieghtliner Pressure Digger Truck (A55973)
2002 Frieghtliner...
2020 Bobcat E42 R2 Series (A60462)
2020 Bobcat E42 R2...
2008 Kubota M125X (A60462)
2008 Kubota M125X...
CATERPILLAR CB24B DOUBLE DRUM ROLLER (A52707)
CATERPILLAR CB24B...
GRID SHAPED BUCKET FOR MINI EXCAVATOR (A58214)
GRID SHAPED BUCKET...
