Loader LK 2554 and LK 3054 Hydraulic Pump Upgrade
/ LK 2554 and LK 3054 Hydraulic Pump Upgrade
I marked the first picture I marked the hoses and diverter knob.
P=Power to loader valve
T=Return to tank
PB=Power beyond from loader valve that feeds 3pt hitch
The knob is circled in green and needs to be all the way clockwise to feed the loader valve.
64560655-0904-44BE-B672-8F93EA0DD257.jpeg B55901AC-F1B9-4D6D-840B-35F0FA4B934F.jpeg
/ LK 2554 and LK 3054 Hydraulic Pump Upgrade #22
I put the pressure gauge on the curl function of the loader valve. I will have to take more pictures tomorrow but they have a couple different priority valves so yours may look different.
When you add a loader you have to turn the knob on the priority valve clockwise to direct flow thru the power beyond port. I will get a picture of that as well. Hope that helps.
Thanks for the response. Looks as though I have a lot to learn. I thought an addition of the loader would be pretty much plug and play.
No problem I am glad to help.
Can you post a picture of your loader valve? You should have 7 total hoses connected. 4 to the cylinders, 1 to the power in, 1 to the tank port and 1 from the power beyond port.
/ LK 2554 and LK 3054 Hydraulic Pump Upgrade #24
/ LK 2554 and LK 3054 Hydraulic Pump Upgrade #25
T=Return to tank
View attachment 700484 View attachment 700485
Sorry about the crazy pictures. My computer is acting up and having a terrible time attaching files. This is only one of several.
Can you confirm you have hoses correct?
P=Power in
T=Out to tank
PB=Power Beyond
/ LK 2554 and LK 3054 Hydraulic Pump Upgrade #27
Here are the 3 hoses that go down to the block on the tractor
Giyi 2WD Mini QA Excavator Arm (A60463)
Giyi 2WD Mini QA...
2018 Keystone Outback Super-Lite 330RL T/A Travel Trailer (A59231)
2018 Keystone...
20FT X 12FT LIVESTOCK METAL SHED (A58214)
20FT X 12FT...
2020 Westfield MKX 100-83 Auger with Swing Hopper (A61307)
2020 Westfield MKX...
DSP 900 Balancer with Split Weight (A61307)
DSP 900 Balancer...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
