Anyone modify their land plane to mount and use on the FEL?
   / Anyone modify their land plane to mount and use on the FEL? #1
FTG-05
Elite Member
TN
Kubota L4330 GST w/FEL, Kubota RTV-XG850, Kubota ZD326S
I don't recall where I got the idea, but I wonder if it would work. I could use the land plane/land leveler on the front leveling the road, then follow it up with my EA grader blade on the back.
Having it on the front would mean that the tires and wheels are driving over less rough terrain meaning the front will dip and rise much less. That's the theory anyway.
Thoughts?
   / Anyone modify their land plane to mount and use on the FEL? #2
i dont know of any compact tractor loader that would stand up to that kind of stress. you would really have to watch for issues. Maybe build a frame mount lift just for that.
   / Anyone modify their land plane to mount and use on the FEL? #3
I can't see how loader arms or mounts would hold up for more than a short distance. People have posted several times how they bent or broke them under a whole lot less stress.
   / Anyone modify their land plane to mount and use on the FEL? #4
I have a skid steer style 6 foot wide land plane on the front of the 5 foot wide Toolcat. Works gooder-un in the clay.
Have not used it much on gravel yet, but I need to.
   / Anyone modify their land plane to mount and use on the FEL? #5
Here is one way to convert a 3 point land plane or box blade for light duty work:
   / Anyone modify their land plane to mount and use on the FEL? #6
2016 I bought a used Kubota B26 from a local rental business. He also brought over a landpride land plane to try. He had modified with ssqa plate on the back. I used it with as 3pt on a bigger tractor. Didn’t buy it but after seeing the the results bought a EA LP.
Do think it would take a stout loader like a skidsteer to operate.
Would like to think my M59 could out pull a skidsteer. There are places on my driveway a 6’ LP strains my machine for traction. Some equipment works better pulled.
   / Anyone modify their land plane to mount and use on the FEL? #7
I sure wouldn't want to put my Land Pride LPGS on my Kubota M6040 FEL. It's a 2584 and is a pretty fair pull on the 3-point on certain parts of my driveway. Beside - most of the time I run the LPGS with the scarifiers down an inch or so - just more load to pull.
   / Anyone modify their land plane to mount and use on the FEL? #9
I have a roadboss like xfaxman posted and have pushed it literally hundreds of miles with skid steers and it works great. I have never connected it to a tractor. As others have said I don’t think tractor loader arms would handle the stress.
   / Anyone modify their land plane to mount and use on the FEL? #10
Yep, that is one reason that I graduated from tractors to better machines for what I need to do.
2002 Bobcat 763 Compact Skid Steer (A56435)
2002 Bobcat 763...
2014 MACK PINNACLE (A55745)
2014 MACK PINNACLE...
2018 Ford Explorer AWD SUV (A56859)
2018 Ford Explorer...
2007 IC Corporation PB105 School Bus (A54814)
2007 IC...
Kubota K7874 18in. Bucket (A55973)
Kubota K7874 18in...
Adams 6Ton Hydraulic Lime Spreader (A55315)
Adams 6Ton...
