Tool box for compact tractor
/ Tool box for compact tractor #1
Alan46
Elite Member
Estacada Oregon
KiotiCK25 HST
Hi all, I have a Kioti ck25 compact does anyone have any photos of a toolbox mounted somewhere on a compact tractor or an idea of what to use and where to mount it? Thanks in advance......🇺🇸✌🏻
Quote Reply
Report Edit Delete
Lots of folks replace the right-hand step with a toolbox. The step is worthless when you have a loader because the joystick is in the way.
Thanks for the reply. I'm going to install a wood platform to that small step so I can fasten my tool box to it!☮✌🏻
/ Tool box for compact tractor #4
I plan on eventually removing the right hand step completely and using the existing mounting holes to add a fabricated tool box bracket. I plan to cut up the step to widen the step on the left side. Existing step is to narrow when wearing heavy boots.
/ Tool box for compact tractor #6
Very nice job.
/ Tool box for compact tractor #7
Yes - that's a fine job. Looks OEM. A suggestion - keep a close eye on the box. If it rattles, shakes, etc - might be good to put a single strip of sticky backed foam tape on the box lid. Don't want the top of the box making direct contact with the glass door. Better to have a foam strip as a buffer.
/ Tool box for compact tractor #9
We chose to make our tool box a removable platform. It rests on the ROPS mount and wraps the ROPS bar but stays in place beautifully. We carry tools, chains, rope, and miscellaneous pins and such. We can add a third box if needed.
/ Tool box for compact tractor #10
Lot good ideas have been posted...try SEARCH.
/ Tool box for compact tractor #12
Great idea! Love your SUN ROOF bro. Thanks for the reply. ☮✌🏻
Yeah that is a bit Rube... the pvc pipe was done to give us a ladder and tool carrier - long tools.. Then I got a less bright idea to block some sun.. it's a work in progress. I need to do something more substantial than just slap scraps from another project up there.
The PVC pipe is completely removable, its light, and is fastened with pins. That part works great. The roof.. that could use a bit more thinking...
Don't want a cab but when we are mowing fields, having something to help give relief from the sun is a plus.
/ Tool box for compact tractor #13
Here'rer a couple pics that show the toolbox on the 2025R. It's the same one that was on the lemony 1025R and the same place. Think the dealer just had it moved for me.
Thanks Ralph. ☮✌🏻
2022 EZ-GO ELITE...
New/Unused Landhonor 78in Rock Bucket with Teeth (A65583)
New/Unused...
2001 WORKHORSE CONVERTED TO FOOD TRUCK (A59914)
2001 WORKHORSE...
2006 John Deere 5425 (A64126)
2006 John Deere...
2020 CATERPILLAR 140 MOTORGRADER (A63276)
2020 CATERPILLAR...
2014 VOLVO A40G WATER TRUCK (A62129)
2014 VOLVO A40G...
