Boomer 41 regenerationbypass
   / Boomer 41 regenerationbypass #11
You're absolutely right! I got mixed up between the Boomer 41 (with the Shibaura engine) and the Boomer 45 (with the LS Mitron L3C19-T engine(my tractor), this happens more than I'd like to admit)
That might change things, and I would hate that regen cycle. However, your tractor would probably still turn into a brick if you bypass that filter and do nothing to the ECU. That said, I am not too familiar with that engine. Hopefully someone can guide you better than I.
Still interested though.
I have no idea how the regen works on that model but my MF1835M is a gen 5 and the regen is about every 50 hours and not noticeable. One thing I do is run it at high rpms pretty much all the time. A tech gave me this advice because it keeps the exhaust hot and lessens the need for an early regen. I'm not sure it this is true, since I have no prior experience with this motor to base that on. I just know the regen is essentially unnoticeable other than a light that occasionally comes on. Maybe the high rpms are helping, maybe not. I just roll with what works. lol
   / Boomer 41 regenerationbypass #12
One thing I do is run it at high rpms pretty much all the time. A tech gave me this advice because it keeps the exhaust hot and lessens the need for an early regen. ... Maybe the high rpms are helping, maybe not. I just roll with what works. lol
When you have 40 hp on tap and regularly use bearely half of it... Instead of wet-stacking the DPF loads up and triggers a regen.
So the mystery is solved. Went to NH dealer, they let me talk to a mechanic. After listening to my story he said “ sounds like a fuel problem to me”. I didn’t know when fuel filters were last changed. When I changed the secondary filter I found it had water in bottom, there is also a sensor there that talks to the CPU. After changing both filters everything is back to normal. Just thought I’d let you know what I found. Chris
New problem, Massey Ferguson 231 steering cylinders leaking. Tried reseal kit, no success. What is the secret? Where is the best place to just get new ones? Thanks,Chris
2014 Ford Escape SUV (A55853)
2014 Ford Escape...
2021 New Holland C327 Compact Track Loader (A55302)
2021 New Holland...
UNUSED Red Corrugated Polycarbonate Roof Panel (A53117)
UNUSED Red...
2019 FREIGHTLINER CASCADIA SLEEPER (A56129)
2019 FREIGHTLINER...
1999 Volvo VN Truck, VIN # 4VG7BBRFXXN772814 (A54865)
1999 Volvo VN...
Tiger Mower Hydraulic Tank Connection (A51691)
Tiger Mower...
